VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
stop saving document
3 REPLIES 3
a7v1n
219 Views, 3 Replies
Hi. Is there any code that makes the drawing file unsavable? Or change the drawing to read only when the user tries to save the drawing? Thanks a lot.
3 REPLIES 3
bigr1822
in reply to: a7v1n
If someone has the answer for the, not being able to save the file, I would love to hear it.
You can close the drawing using, "thisdrawing.close"
change the attributes using"SetAttr , vbReadOnly
then open the drawing using, "thisdrawing.open(filename & Location as string)
I wanted to use this for our Electrical software, but not going to work. I would like the file to just not be saveable!
Rodney
rocheey
in reply to: a7v1n
Im guessing you can intercept the save event; Ive seen shareware for Acad that did much the same... and as such, was equally as easy to bypass using the VBA API
cadger
in reply to: a7v1n
i thought the same, and something like this could work for saveas but seems too slow for qsave, don't know if it would work for a larger dwg, but doubt it... please excuse the sendkeys...
{code}
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
If CommandName = "QSAVE" Then
'MsgBox ("NO SAVE!")
'AppActivate ThisDrawing.Application.Caption
SendKeys "{ESC}" & "{ESC}" & "{ESC}", False
End Sub
{code}
”Boost
