I am working with a lisp that step through layers one at a time, locking all other layers than current one. (enter or space)
While this lisp runs I can zoom etc in the drawing.
Is it possible to make this tool with VBA too?
gr. Laszlo
defun C:STL (/ *error* cmde lay) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg)) ); end if (command "_.layer" "_unlock" "*" "") (setvar 'cmdecho cmde) ); end defun - *error* (setq cmde (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (getstring "\nPress Space or Enter to go to next Layer, Escape to quit: ") (setq lay (cdr (assoc 2 (tblnext "layer" (not lay))))) (while (and lay (wcmatch lay "*|*") (setq lay (cdr (assoc 2 (tblnext "layer")))))); (if (not lay) (setq lay (cdr (assoc 2 (tblnext "layer" T))))); back to 0 at end (command "_.layer" "_thaw" lay "_set" lay "_lock" "*" "_unlock" lay "" "_regen") ); end while ); end defun (princ "\nType STL to Step Through Layers, locking all other Layers.") (princ)
Solved by truss_85. Go to Solution.
I am afraid it is not but it might be possible another way but you can execute command each time. It continues to which layer did you left.
