VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
SetWindowToPlot Coordinates
5 REPLIES 5
953 Views, 5 Replies
Does anyone know a reason that 9000 or so would be added to coordinates
passed to SetWindowToPlot?
ThisDrawing.ActiveLayout.RefreshPlotDeviceInfo
Set oPltConf = ThisDrawing.PlotConfigurations("DwfExport")
With oPltConf
.PlotType = acWindow
.SetWindowToPlot dLowLt, dUprRt
.UseStandardScale = True
.StandardScale = acScaleToFit
End With
If I do a -PLOT at the command line, the coordinates are 'shifted' from what
was passed. I've verified this by drawing a line to the points used above.
No UCSs are present...........I'm stumped. The distance between the lower
left/upper right is good.........just shifted 9000 units.
5 REPLIES 5
In case anyone else stumbles across something like this, the following 'work
around' does work, but I would like to know the true answer to the original
post
Dim sPlotString As String
sPlotString = "-plot yes" & vbCr & vbCr & vbCr & vbCr & vbCr & vbCr &
vbCr & vbCr & _
Format(dLowLt(0), "0.00") & "," & Format(dLowLt(1),
"0.00") & vbCr & _
Format(dUprRt(0), "0.00") & "," & Format(dUprRt(1),
"0.00") & vbCr & _
vbCr & vbCr & vbCr & vbCr & vbCr & vbCr & _
sDwfNam & vbCr
If Dir(sDwfNam) <> "" Then sPlotString = sPlotString & "Y" & vbCr
sPlotString = sPlotString & "n" & vbCr & "y" & vbCr
ThisDrawing.SendCommand sPlotString
While googling this problem earlier this afternoon I came across an old
(several years) post of mine about a similar issue. I've used the
SetWindowToPlot in a couple of other macros without problem since then, so
I'm wondering what I'm missing with all of this.
yiginiamre
Hay Tom,
The year is 2008, the month is May and the cad version is AutoCAD 2008.
Guess what, I just spent five days trying to solve the same problem. So I guess Autodesk well fix this problem in the AutoCAD 3008.
Thanks for the Post Tom.
-J
absStructural
1-29-2013, using AutoCAD 2012... and I'm experiencing this issue on 'some' drawings.  Again, no UCS is present... it just doesn't make any sense.
Well - in case anyone else runs across this... I found the answer here: http://forums.autodesk.com/t5/Visual-Basic-Customization/ActiveX-SetPlotWindow/td-p/321369
In short, SetWindowToPlot expects the values in DCS (Display Coordinate System).  DCS is not always equal to WCS - so you have to translate the points from WCS to DCS.  I am still a bit puzzled by the fact that 95% of the time (if not more) DCS == WCS.
lbhthriller
in reply to: absStructural
Thank you very much for your answer!
”Boost
