VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Set all blocks to scale uniformly
2 REPLIES 2
489 Views, 2 Replies
so i've been trying to make a routine forever that will set all the blocks to scale uniformly without success... until today!! in case anybody else is having trouble doing the same thing, i thought it would be nice of me to post my code B)
Lisp part:
(defun c:bsu ()
(princ "\nBlock Scale Uniformly\n")
(vl-vbaload (strcat home "/vba/timVBA.dvb"))
(vl-vbarun "block_scale_uniformly")
(princ)
VBA Part:
Public Sub block_scale_uniformly()
Dim block As AcadBlock
Dim entity As AcadEntity
For Each block In ThisDrawing.Blocks
If "*Model_Space" = block.Name Or "*MODEL_SPACE" = block.Name Then
GoTo nextblock
Else
If "*Paper_Space" = block.Name Or "*PAPER_SPACE" = block.Name Then
GoTo nextblock
Else
block.BlockScaling = acUniform
End If
End If
nextblock:
Next block
End Sub
2 REPLIES 2
msarqui
Sorry for the question but how to use it?
Alfred.NESWADBA
in reply to: msarqui
Start command _VBAIDE (if you need a VBA-Enabler then install it from >>>here<<<), then copy the "VBA part" from the original message into the code-window of VBAIDE. Having done that (and maybe saved the project) you can go back to AutoCAD, then start command _VBARUN and select the item block_scale_uniformly to be executed.
Just to make sure: that's a description how you can use it, I have not tested the code (as e.g. XRefs might be a problem here).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
