Ok, a bit more detail...
Dim LayerName as String
LayerName = "MyCoolLayer"
ThisDrawing.Layers.Add(LayerName)
This is good. Permits you to change the layer name sometime in the future at
one point.
acXREFS.Layer = "XREFS"
This is bad. In the same procedure you have used a "hard-coded" string. So
if you change the string for the variable, and *forget* to look for other
instances of that string in the procedure, you have created a bug.
It would be far better to do this, in the 2nd case:
acXREFS.Layer = LayerName
This way, you only need to change the string in one place, and be confident
that the rest of the code will still work.
R. Robert Bell, MCSE
www.AcadX.com
"Gilles" wrote in message
news:C91FC2F023959C91326BDC5063545FE9@in.WebX.maYIadrTaRb...
| Thank you for your answer which was much more efficient than my first
code.
| I tried it through a few drawings and everything is OK... As a new user I
| am everyday surprised by the potential of VBA but I need to learn some (
| what dou I say... a lot of) things to succeed in my objectives.
| By the way, what do you mean exactly by "BTW, you used a variable for the
| layer name in one spot, and the actual string in another (can you spell
| p-o-t-e-n-t-i-a-l b-u-g? )". What I understand is that I should use the
| same variable to declare the layer name and layer object ??? ... ???
| Thanks again....
| Gilles
| ----- Original Message -----
| Newsgroups: autodesk.autocad.customization.vba
| Sent: Wednesday, May 28, 2003 7:12 PM
| Subject: Re: selecting all xrefs in modelspace
| > What if ModelSpace has objects *other* than XRefs?! 😉
| > Public Sub Test()
| > Dim Layer_Name As String
| > Layer_Name = "XREFS"
| > Dim layerXREFS As AcadLayer
| > Set layerXREFS = ThisDrawing.Layers.Add(Layer_Name)
| > layerXREFS.color = acWhite
| > layerXREFS.LayerOn = True
| > layerXREFS.Linetype = "continuous"
| > layerXREFS.Lock = False
| > layerXREFS.PlotStyleName = "Normal"
| > layerXREFS.Lineweight = acLnWtByLwDefault
| > layerXREFS.Plottable = True
| > Dim thisObj As AcadEntity
| > For Each thisObj In ThisDrawing.ModelSpace
| > If TypeOf thisObj Is AcadExternalReference Then thisObj.Layer =
| > Layer_Name
| > Next thisObj
| > End Sub
| > BTW, you used a variable for the layer name in one spot, and the actual
| > string in another (can you spell p-o-t-e-n-t-i-a-l b-u-g? )
| > www.AcadX.com
| > news:074A51AC13DB08BC531859BBAA5F631E@in.WebX.maYIadrTaRb...
| > | Hello all,
| > | How can I select all xrefs attached in a modelspace drawing and change
| > their
| > | layer into "XREFS" for example ???
| > | Here is the code I created but it does not work in all my drawings.
| Don't
| > | understand why...
| > | 1° When I create a new drawing and attach XREFS inside it (in
| modelspace)
| > it
| > | works fine.
| > | 2° But when I try it in existing files it doesn't work any more.....
| > | I would really appreciate if someone more experienced than I am could
| help
| > | me.
| > | Thanks
| > | Gilles
| > | Option Explicit
| > | Public Sub Add_Layer_Vport()
| > | layerXREFS.Color = acWhite
| > | Dim acXREFS As AcadExternalReference
| > | For Each acXREFS In ThisDrawing.ModelSpace
| > | Next acXREFS
| > | End Sub
