Chuck,
can you please post the method you mentioned to prevent clearing...?
thanks
Kevin
"Chuck Gabriel" wrote in message
news:B39D8681A5CEDB82D6862D91E15F3F04@in.WebX.maYIadrTaRb...
> I am assuming you have already figured out how to work around the problem
> with the PickfirstSelectionSet clearing when your macro starts. I you
> haven't, post back here, and I will show you one way.
> Now regarding your specific question, just check the Count property of the
> PickfirstSelectionSet.
> If ThisDrawing.PickfirstSelectionSet.Count = 1 Then
> 'Only one object is selected
> End if
> Do you also need help in determining if the object is part of a specific
> group?
> Chuck
> "Mark Dubbelaar" wrote in message
> news:E52A515A6571E9B58D18688B5BB4845E@in.WebX.maYIadrTaRb...
> > hi
> > is it possible through vba to determine if only one item is selected....
i
> > wish to use the BeginDoubleClick event to display a dialog box, if the
> item
> > selected is a part of a specific group
> > thanks in advance
> > cheers
> > mark
