Now I have tried acadunsupp2000, but it doen't seem like it can do the job.
I press a button in a form, and from the data in the form, a selectionset is
built.
acadunsupp2000 gave me an error when run liek a macro, but worked fine when
I "stepped" through the code. (As it say it would in the example)
So... How can it be done with the AcadX server?
Trond Hasse Lie
Norway
"Tony Tanzillo" wrote in message
news:3998EC4D.FBC0D9B7@worldnet.att.net...
> My AcadX server, and AcadUnsupp2000 both allow you to
> set Active Selection set.
> Trond Hasse Lie wrote:
> > Hi.
> > I was just wondering if anyone know how I can use VBA to select objects
in
> > the drawing, so that the grips are enabeled/shown. The editing of the
object
> > will be done manually in AutoCAD. All I want for VBA to do, is to select
> > them.
> > Trond Hasse Lie
> > Norway
> Checkout the AcadX(tm) ActiveX Extension Library at:
> http://www.caddzone.com/acadx/acadx.htm
> /* Tony Tanzillo Design Automation Consulting */
> /* Programming & Customization for AutoCAD & Compatibles */
> /* tony.tanzillo@worldnet.att.net */
> /* http://www.caddzone.com */
