VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Search in proximity of block
1 REPLY 1
349 Views, 1 Reply
I have been breaking my head on how to go about the following challange: I have a layer with certain blocks. On another layer there are text objects always close to the mentioned blocks. I need to find the text directly in vicinity of the objects (can be verified with regexes) and add this text as an attibute to this block. Greatful for any assisance
1 REPLY 1
DavidTosh
With a similar goal, I've used the following steps:
 - create a bounding polygon for the block. (try to use a rectangle if possible.)
 - expand the bounding polygon to enclose the related text.
 - use the polygon for a window-limited selection set.
 - add, if useful, filters in the selection set for the text's layer and for the text object type.
 - iterate through the items in the selection set, qualifying the text with your regex - if needed.
Your success will depend on the uniformity of your drafting conventions. (How "directly in the vicinity" the text actually is.)
Tosh
”Boost
