Running VBA Macro with Parameter from Autocad Command line
How do you run a vba macro using a variable as a command line item?
I would expect it would be something like this, but it does not work.
-vbarun SiteMenu.SetSiteMenu 5
Where SiteMenu.SetSiteMenu is the macro and 5 is the variable that I want to
pass.
The sub code looks like
Sub SetSiteMenu(intMenu as Integer)
Exit
I don't think you can run a macro that takes parameters from the command line.
I found this a while ago in the Autodesk AutoCAD Knowledge base:
No, it is not possible to pass parameters from the program directly into a
VBA macro. However, you can use the GetString function in VBA and the
AutoLISP® (command) function to pass data. This example shows how to pass
data using VBA and AutoLISP to a VBA macro:
In the MODULE:
Public Param1, Param2 As StringSub MyMacro()Param1 =
ThisDrawing.Utility.GetString(False) Param2 =
ThisDrawing.Utility.GetString(False) 'Enter your code hereEnd
SubThen call the VBA macro as:
(command "-VBARUN" " MyMacro " "Argument1"
"Argument2")--------------------------------I have used this and it works
very well.Hope it helps.
Dave
You can't run a macro that takes parameters from the command line.
For single var's use the system var's USERx1-5, for complex informations
use dictionaries to exchange values between vba macros and menu-/lisp.
Cheers
Juerg Menzi
MENZI ENGINEERING GmbH, Switzerland
http://www.menziengineering.ch
P.S.
I have also used used USERS1 - USERS5 to hold strings so that VBA can pick
them up.
Ken
"Dave Mikolaitis" wrote in message
news:[email protected]...
to
> pass.
> Exit
The getstring method will work, but you can also use lisp setq to store the
values in lisp variables and then recover them in VB/VBA using the Vlax class. I
use this sometimes to 'park' values in lisp when my VB program will not always
know which form will create and/or retrieve the data. Saves declaring a global
variable for an 'on the fly' value.
Tom
> pass.
> Exit
