VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Reverse Polyline - With Bulges - Last Bulge Problem
4 REPLIES 4
865 Views, 4 Replies
Ok, I'm writing a VBA to reverse the direction of a closed polyline, with bulges. I've pulled code from this forum (Thank yall very much) and it seems to be working except where the last point joins the first. If there is a bulge between the last point and the first point, it doesn't seem to register, and when the reversal is finished, the last bulge is reversed.
Is there a trick to getting and/or setting the bulge between the last and first points of a closed polyline? If I get the bulge from the last point, it says Zero, even though it's rounded.
I'm at the end of my day here, so I can't post code right now, but I'll toss it in here tomorrow.
Thanks.
4 REPLIES 4
Uh oh, no responses yet. Hope someone can help me figure this out.
As an example, draw a rectangle using RECTANG, then use FILLET to round off the corners. That'll be the GuineaPig. Here's the code I got from this forum. I forgot the name, but thank you very much.
Private Sub ReversePline(plineObj As AcadEntity)
Dim pts() As Double
Dim bulge() As Double
Dim legs As Integer
Dim retcoord As Variant
Dim i As Integer
Dim i2 As Integer
Dim FN As Long
'--- I added some code to write bulges to a text file so I can see what its doing ---
FN = FreeFile
Open "C:\bulge.txt" For Output As #FN
retcoord = plineObj.Coordinates
ReDim Preserve pts(UBound(retcoord))
legs = (UBound(retcoord) / 2) - 1
ReDim Preserve bulge(legs)
For i = legs To 0 Step -1
Print #FN, i & " = " & CStr(plineObj.GetBulge(legs - i))
bulge(i) = plineObj.GetBulge(legs - i) * -1
Next i
For i = UBound(retcoord) To 0 Step -2
i2 = UBound(retcoord) - i
pts(i2 + 1) = retcoord(i)
pts(i2) = retcoord(i - 1)
Next i
plineObj.Coordinates = pts
For i = 0 To legs
plineObj.SetBulge i, bulge(i)
Next i
Close #FN
End Sub
Eureka! (eeka...eeka) I figgered it out.
I went back and applied a little brute force tactics, making OLDX and OLDY then swapping NEWX and NEWY, etc. Not very elegant, but "Life is pain. Get used to it." (Name that movie.)
Anyway, it worked, and I'll post it below for anyone who's interested.
Dim pts() As Double
Dim OLDptX() As Double
Dim OLDptY() As Double
Dim NEWptX() As Double
Dim NEWptY() As Double
Dim legs As Integer
Dim i As Integer
Dim iOLD As Integer
Dim iNEW As Integer
legs = ((UBound(retcoord) + 1) / 2) - 1
ReDim Preserve OLDptX(legs)
ReDim Preserve OLDptY(legs)
ReDim Preserve NEWptX(legs)
ReDim Preserve NEWptY(legs)
'\\\Establish Points Array from PolyLine Coords
For i = 0 To UBound(retcoord)
pts(i) = retcoord(i)
Next i
'\\\Keep PointZero the same and Reverse Remaining Points
'\\\Brute Force Method (Ugh *scratch scratch*)
iNEW = legs
For iOLD = 1 To legs
OLDptX(iOLD) = pts(iOLD * 2)
OLDptY(iOLD) = pts((iOLD * 2) + 1)
NEWptX(iNEW) = OLDptX(iOLD)
NEWptY(iNEW) = OLDptY(iOLD)
iNEW = iNEW - 1
Next iOLD
'\\\NOTE-New Points Gathered, but Not Applied Yet
'\\\Get Bulges in Reverse Order and Make Them Negative
For i = 0 To legs
Next i
'\\\Reverse All Points Except PointZero (Apply New Points)
For i = 1 To legs
pts(i * 2) = NEWptX(i)
pts((i * 2) + 1) = NEWptY(i)
Next i
'\\\Give New Points to PolyLine
'\\\Set New Bulges
For i = 0 To legs
Next i
plineObj.Update
End Sub
another option
just changed your indexes slightly
seems to work
AcadEntity)
Dim pts() As Double
Dim legs As
Integer
Dim i As Integer
Dim i2 As
Integer
Dim FN As Long
FN = FreeFile
Output As #FN
ReDim Preserve
'changed legs calc
'changed index
For i = legs To 1 Step -1
'Print #FN, i & " = " &
CStr(plineObj.GetBulge(i - 1))
'bulge(i) = plineObj.GetBulge(legs - i) *
-1
bulge(i - 1) = plineObj.GetBulge(i - 1) * -1
Next i
i2 =
1)
Next i
'changed index
For i = 0 To legs - 1
Print #FN, i
& " = " & CStr(plineObj.GetBulge(i))
Next i
Close #FN
End
Sub
hth
mark
Eureka!
Anyway,
snip
suphit
Public Sub ReversePolyline()
Dim NewCoords() As Double
Dim Bulge() As Double
Dim Segm() As Double
Dim Bul As Double
Dim OldCoords As Variant
Dim Entity As AcadEntity
Dim legs As Integer
Dim I As Integer
Dim J As Integer
Dim N As Integer
OldCoords = plineObj.Coordinates
ReDim NewCoords(LBound(OldCoords) To UBound(OldCoords)) As Double
J = LBound(NewCoords)
For I = UBound(OldCoords) To LBound(OldCoords) + 1 Step -2
NewCoords(J) = OldCoords(I - 1)
NewCoords(J + 1) = OldCoords(I)
J = J + 2
Next I
N = 0
For I = LBound(OldCoords) To UBound(OldCoords) - 2 Step 2
Bul = plineObj.GetBulge(I / 2)
N = N + 1
ReDim Preserve Bulge(N)
ReDim Preserve Segm(N)
Bulge(N) = Bul * -1
Segm(N - 1) = (I / 2)
Next I
Segm(N) = N
plineObj.SetBulge Segm(I / 2), 0
Next I
For I = 0 To N - 1
plineObj.SetBulge Segm(I + 1) - 1, Bulge(N - I)
Next I
plineObj.SetBulge Segm(N), Bulge(1)
plineObj.Coordinates = NewCoords
plineObj.Update
End Sub
”Boost
