And the reason you didn't see the error is the "On Error Resume Next" at the
top of CommandButton2_Click(). It is the root of much evil. Get rid of it,
or at least reset the error handler immediately after.you've checked for the
error.
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
wrote in message news:5252497@discussion.autodesk.com...
I have some code which should read an excel file. When I use the buttons my
Listbox remains empty. I have loaded the Excel Object Library. What is
wrong?
Private Sub CommandButton1_Click()
Dim excelApp As Excel.Application
Dim wbkObj As Workbook
Dim shtObj As WorkSheet
UserForm1.Hide
Err.Clear
Set excelApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set excelApp = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Cannot start Excel", vbExclamation
End
excelApp.Visible = True
Set wbkObj = excelApp.Workbooks.Open("C:\Bob\Test.xls")
Set shtObj = excelApp.Worksheets(1)
UserForm1.Show
End Sub
Private Sub CommandButton2_Click()
Dim i As Integer
Dim txt As String
UserForm1.Hide
Err.Clear
Set excelApp = GetObject(, "Excel.Appication")
ListBox1.Clear
i = 1
txt = shtObj.Cells(i, 2)
Do While txt <> ""
ListBox1.AddItem txt
i = i + 1
Loop
UserForm1.Show
End Sub
