VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Quick question on text
1 REPLY 1
271 Views, 1 Reply
As you guys can probably tell I am completely new to autocad and vba.  i was wondering if there is a way I can simply write a text in vba and give it a position along with the text height and have it placed at a point "TextPoint" in autocad.
Thanks a bunch
1 REPLY 1
truss_85
Acad text will do that why do you need programming for this? I suggest to you take look help menu.
From help menu...
Sub Example_AddText()
    ' This example creates a text object in model space.
    Dim textObj As AcadText
    Dim textString As String
    Dim insertionPoint(0 To 2) As Double
    Dim height As Double
    ' Define the text object
    textString = "Hello, World."
    insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    ZoomAll
End Sub
”Boost
