VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Problem With Intersectwith option in VBA
2 REPLIES 2
718 Views, 2 Replies
I have a problem with the intersectwith option when trying to compare text
that intersects. I get a return if the text has the same rotation angle, or
if the text is 90 degrees perpendicular to one another. I do not get a
return if the text is rotated on any other angle. For example, if I have
one piece of text that is at 0 degrees, and I have another piece of text
that crosses that text at a 45 degree angle, the intersectwith option does
not return any points of intersection, even though they clearly intersect.
If those same two pieces of text are rotated at 0 degrees, or if one piece
is at 90 and the other is at 0, the intersectwith option returns all of the
intersection points.
Does anybody know why? Is this a bug with the intersectwith option in VBA?
Sam Bell
2 REPLIES 2
Hi Sam,
I haven't tried the intersectwith method with text, but you may want to
check out the extend options for the method. Or worse comes to worse
create 2 rays starting at the insert points and heading in the direction
of the textangles, run the intersectwith method on them, and delete them
when finished.
-Josh
> Thanks,
> Sam Bell
abhishekkalamkar1010
 I wanna intersect Block Reference object with Polyline object  and get the Object data of Block Reference and need to update the object data in polyline object.
kindly advice me.
Thanks in Advance !!
”Boost
