VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Problem with acCTRL
5 REPLIES 5
doc_x
544 Views, 5 Replies
Problem with acCTRL
Hi !
I'm using that component. It's very good to my routines. But a problem has happened: When I put mouse on graphical environment and press key F2, so it 's lunching  total cad to front my application. Is it possible avoid that happen ?
I want to say, disable F2 from autoCad ? I'm using 2010 version.
Thanks !
5 REPLIES 5
doc_x
in reply to: doc_x
Nobody knows ?
I 'd like a simple direction.
Thanks !
andrewpuller3811
in reply to: doc_x
Try looking up "shortcut keys" in the help.
In the CUI editor you can assign the "Cancel" which contains "^C^C" in the macro to the "F2" Key.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
doc_x
in reply to: doc_x
Thanks! I'll try !
doc_x
in reply to: doc_x
Hi Andrew, unhappylli I did not get yet.
andrewpuller3811
in reply to: doc_x
What did you try? Write out the steps.
Maybe attach a screen shot.
Andrew Puller
Civil 3d 2021
”Boost
