Plugins (exe, vb6) doesn't work well on win 10
viper_007
viper_007
I have some plugins (exe, developed by vb6 not vba), which work completely well on win 7, draw some lines on the cad drawing. But when I try to run them on win 10, it fails with the exception "runtime error 91: object variable or with block variable not set".
I wonder if there are any solutions to this problem.
聚傲气于一身,显傲骨之精华
Alfred.NESWADBA
>>>there<<< you find the description to the message, without seeing the code it's not possible now to say what at your site is the reason for that exception.
It might be possible that
  • you had installed some lib's which you don't have now.
  • you where working on 32bit on your WIndows 7 while now working on 64bit operating system (and AutoCAD)
  • you had another version of AutoCAD running.
  • ... and more
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
viper_007
os: win 7 pro 64 and win 10 home 64
both AutoCAD 2011 64bit installed
聚傲气于一身,显傲骨之精华
Alfred.NESWADBA
well, AutoCAD 2011 on Windows 10 is a risk by itself (as AutoCAD 2011 is not supported/tested on Windows 10)
So your questions will stay open as long as you don't debug and look to the line of code the error is raising up.
- alfred -
Alfred NESWADBA
viper_007
When I edit registry key HKEY_LOCAL_MACHINE --> SOFTWARE --> Microsoft --> Windows --> CurruntVersion --> Policies -->System, set EnableLUA value to 0, and guess what, the vb exe works! Maybe It's something about privilege that blocks the autocad type lib.
Alfred, thank you all the same!
聚傲气于一身,显傲骨之精华
