VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Open dwg file from code
2 REPLIES 2
OceanaPolynom
482 Views, 2 Replies
Hello
I want to open a dwg file from code in my program.  I have a string variable containing the full path and file name.  I want to open the dwg file in an instance of Autocad that is already running, I don't want to open Autocad.  The program is written in VB 6.0.  Is this possible?
Thank you
John
Tags (2)
2 REPLIES 2
yes, is possible, use COM/ActiveX to get access to the running AutoCAD instance and start controlling it.
   Dim tAcadApp as AcadApplication   'or    as Object     if you use latebinding
   Set tAcadApp = getObject(,"AutoCAD.Application")
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Thanks for your reply.  I am finding out what this is meanwhile
John
”Boost
