VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
One Error was found in the drawing file during open - using VBA & Attributes
0 REPLIES 0
Message 1 of 1
Hawthorn76
580 Views, 0 Replies
I have developed a program in Access 2010 that uses VBA to open up an autocad file and write to 4 different attributes. After the change has been made, it saves and closes the file.
When using AutoCAD 2012 and I open the file for the first time, it creates the following error
One Error was found in the drawing file during open Would you like to cancel this open?
This does not occur with AutoCAD 2013 or when i step through the program (using F8 on keyboard ) using AutoCAD 2012.
The code is as follows:
Private Sub CmdUploadSigDatetoDwgs_Click()
Call GetFilePath 'Return File and Path Name and place in array
RecordCounter = 0
On Error Resume Next
'if autocad is already open run this
Set acApp = GetObject(, "AutoCAD.Application")
If Err.Number <> 0 Then 'Not Running
    Set acApp = CreateObject("AutoCAD.Application")
    Err.Clear
    CloseAutoCAD = True
Else
    'Variable to not close autocad
    CloseAutoCAD = False
acApp.Visible = False 'Display / Hide AutoCAD. sometimes crashes
'Loop through Array and return File and Path
For RecordCounter = LBound(FilePathArray) To UBound(FilePathArray)
    FilePathName = FilePathArray(RecordCounter)
    Set aDoc = acApp.Documents.Open(FilePathName)
    For Each po_obj In aDoc.PaperSpace
         If TypeOf po_obj Is AcadBlockReference Then
               If po_obj.HasAttributes Then
                     For CounterNest1 = LBound(att1) To UBound(att1)
                          Select Case att1(CounterNest1).TagString
                                Case "APP"
                                           att1(CounterNest1).TextString = Me.TxtApprovedBy
                                Case "APPDATE"
                                           att1(CounterNest1).TextString = CStr(Me.TxtApprovedByDate)
                               Case "CKD"
                                          att1(CounterNest1).TextString = Me.TxtCheckedBy
                               Case "CKDDATE"
                                         att1(CounterNest1).TextString = CStr(Me.TxtCheckedByDate)
                               End Select
                     Next CounterNest1
               End if
         End if
Next
aDoc.Close True, FilePathName
Next RecordCounter
If CloseAutoCAD = True Then
    acApp.Quit 'Close autoCAD automation
Else
    acApp.WindowState = acMin
Set aDoc = Nothing
Set acApp = Nothing
End Sub
I would appreciate if someone can guide me to a solution,
0 REPLIES 0
”Boost
