I have developed a program in Access 2010 that uses VBA to open up an autocad file and write to 4 different attributes. After the change has been made, it saves and closes the file.
When using AutoCAD 2012 and I open the file for the first time, it creates the following error
One Error was found in the drawing file during open Would you like to cancel this open?
This does not occur with AutoCAD 2013 or when i step through the program (using F8 on keyboard ) using AutoCAD 2012.
The code is as follows:
Private Sub CmdUploadSigDatetoDwgs_Click()
Call GetFilePath 'Return File and Path Name and place in array
RecordCounter = 0
On Error Resume Next
'if autocad is already open run this
Set acApp = GetObject(, "AutoCAD.Application")
If Err.Number <> 0 Then 'Not Running
Set acApp = CreateObject("AutoCAD.Application")
Err.Clear
CloseAutoCAD = True
Else
'Variable to not close autocad
CloseAutoCAD = False
End If
acApp.Visible = False 'Display / Hide AutoCAD. sometimes crashes
'Loop through Array and return File and Path
For RecordCounter = LBound(FilePathArray) To UBound(FilePathArray)
FilePathName = FilePathArray(RecordCounter)
Set aDoc = acApp.Documents.Open(FilePathName)
For Each po_obj In aDoc.PaperSpace
If TypeOf po_obj Is AcadBlockReference Then
If po_obj.HasAttributes Then
For CounterNest1 = LBound(att1) To UBound(att1)
Select Case att1(CounterNest1).TagString
Case "APP"
att1(CounterNest1).TextString = Me.TxtApprovedBy
Case "APPDATE"
att1(CounterNest1).TextString = CStr(Me.TxtApprovedByDate)
Case "CKD"
att1(CounterNest1).TextString = Me.TxtCheckedBy
Case "CKDDATE"
att1(CounterNest1).TextString = CStr(Me.TxtCheckedByDate)
End Select
Next CounterNest1
End if
End if
Next
aDoc.Close True, FilePathName
Next RecordCounter
If CloseAutoCAD = True Then
acApp.Quit 'Close autoCAD automation
Else
acApp.WindowState = acMin
End If
Set aDoc = Nothing
Set acApp = Nothing
End Sub
I would appreciate if someone can guide me to a solution,
