VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
OCS Coordinate system of Block to UCS or WCS Coordinate system ?
7 REPLIES 7
Message 1 of 8
3457 Views, 7 Replies
Hi, everyone!
I want to know how to transform OCS Coordinate of A block object to UCS or WCS Coordinate .
It's Block's OCS   Coordinate  not other objects.
I will  appreciate for your suggestions.
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
look to this method (if you are working with VBA) within ThisDrawing.Utility:
Function TranslateCoordinates(Point, FromCoordSystem As AcCoordinateSystem, ToCoordSystem As AcCoordinateSystem, Displacement As Long, [OCSNormal])
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
in reply to: Alfred.NESWADBA
Thank you, alfred ! I know this function. and I know how to use it to transform  a 3DPolyline's OCS to UCS. but I can't find the last  arguments of the function When I use it to transform Block 's OCS.
In fact I have never found out  the meaning of the last two arguments of this function.
I am eager to more information about this function and I want you give an example about BlockObject's transform. Thank you again.
Message 4 of 8
Alfred.NESWADBA
ok, I understand the problem now as you can convert UCS to WCS and to ScreenCS, but not directly to Block-CS. The problem is that Block-CS differs from the other ones by having a scaling built in and that does not work (at least not with this function).
If you have dotNET, you have access to the BlockReference-Transformation-Matrix, that makes it more easy to get the info's of points within a BlockReference transfered to WCS.
The direction I would go now with VBA is:
  • calculate the vector from your point of request within the Block (block-definition)
  • rotate this vector based on 0,0,0 equal to your BlockReference-Rotation
  • scale this vector based on 0,0,0 equal to your BlockReference-Scaling
  • move this vector from 0,0,0 to the insertion-point of your blockreference
...assuming that the block is inserted parallel to WCS, so not rotated in 3D that should work.
HTH, - alfred -
Alfred NESWADBA
Message 5 of 8
Yes,I am writing code toward this direction.It's  more difficult than you say. The code is short but the calculation of  the mathematical is too complex. But I think I can make it. I will share it  when I  get it completed.
Thank you alfred. You are knowledgeble !
I  think I have more questions to ask later.
Message 6 of 8
I have worked it out. Share it below.
'块的OCS转WCS坐标
'B是块对象,ocsp是一个变体存储遍历块获得块内OCS坐标,WCsp 返回OCSp对于的世界坐标
'江河梦小组  华夏梦清 QQ 772671249 rtx 61692
'2012.5.30
'仅适用于XY面上块对象
Public Sub BOcsToWcs(b As AcadBlockReference, ocsp, Wcsp() As Double)
     Dim X As Double, Y As Double, R As Double, P As Double, Z As Double
     Dim WcsX As Double, WcsY As Double, WcsZ As Double
     Dim Instrpoint As Variant, V1 As Integer, V2 As Integer
     Const Pi As Double = 3.14159265358979
       X = b.XScaleFactor
       Y = b.YScaleFactor
       Z = b.ZScaleFactor
       R = b.Rotation
       Instrpoint = b.InsertionPoint
      '所求均为与x正半轴夹角
        If ocsp(0) > 0 And ocsp(1) = 0 Then 'x正半轴
                R = R + 0
        ElseIf ocsp(0) > 0 And ocsp(1) > 0 Then '第一象限
                R = R + Atn(ocsp(1) / ocsp(0))
        ElseIf ocsp(0) = 0 And ocsp(1) > 0 Then 'y正半轴
                R = R + Pi / 2
        ElseIf ocsp(0) < 0 And ocsp(1) > 0 Then '第二象限
                R = R + Atn(ocsp(1) / ocsp(0)) + Pi
        ElseIf ocsp(0) < 0 And ocsp(1) > 0 Then 'x负半轴
                R = R + Pi
        ElseIf ocsp(0) < 0 And ocsp(1) < 0 Then '第三象限
        ElseIf ocsp(0) = 0 And ocsp(1) < 0 Then 'y负半轴
                R = R + Pi * 3 / 2
        ElseIf ocsp(0) > 0 And ocsp(1) < 0 Then '第四象限
                R = R + Atn(ocsp(1) / ocsp(0)) + 2 * Pi
        Else                                    '原点
                R = R + 0
       P = (ocsp(0) ^ 2 + ocsp(1) ^ 2 + ocsp(2) ^ 2) ^ 0.5 '求的极坐标半径
       '获得相对于插入点的世界坐标
       WcsX = P * Cos(R) * X: WcsY = P * Sin(R) * Y: WcsZ = P * ocsp(2)
       '获得世界坐标
       Wcsp(0) = WcsX + Instrpoint(0)
       Wcsp(1) = WcsY + Instrpoint(1)
       Wcsp(2) = WcsZ + Instrpoint(2)
End Sub
Private Sub CommandButton1_Click()
'测试代码
'建立一个图块,里面包含一个点,测试这个点
Dim Wcsp(0 To 2) As Double
Dim ocsp
 Dim Bref As AcadBlockReference
 Dim Myent As AcadEntity
   On Error Resume Next
  Me.Hide
  ThisDrawing.StartUndoMark
  Do
       ThisDrawing.Utility.GetEntity Bref, pick, "选择测试块"
     DoEvents
         For Each Myent In ThisDrawing.Blocks(Bref.Name)
               If Myent.ObjectName = "AcDbPoint" Then
                    ocsp = Myent.Coordinates
                     BOcsToWcs Bref, ocsp, Wcsp
'                       For i = 0 To 2
'                         Debug.Print Wcsp(i)
'                       Next
'                       Debug.Print "***********"
                       ThisDrawing.ModelSpace.AddCircle Wcsp, 500
        Next
        Debug.Print Err.Number & "--" & Err.Description
  Loop While Err.Number <> -2147352567
  ThisDrawing.EndUndoMark
  ThisDrawing.SendCommand "U" & Chr(13)
  Me.Show 0
End Sub
 The code in the sub of button is just for a test. In the test, you should use  the dwg attachment. Run the test,select a block , it would use the transformed WCS point build  circles.
Thank you alfred.
Message 7 of 8
Hi huaxiamengqing,
What is the OCS and WCS parameters you are passing to the functions? Which coordinates are they?
Thanks in advance
Message 8 of 8
you can translate this sentence by gogle.
 b is a block ocs is a array of pointxyz in block, wcsp is the returned wcsp point
”Boost
