Just made a switch to 2015 and 64 bit cod and when i issue .Utility.GetEntity or .Utility.GetPoint i am not able to pan or orbit anymore?
I can not reproduce it with my AutoCAD 2015. That is, with Utiltity.getEntity()/GetPoint() being called and AutoCAD is hanging for user to pick, I can zoom/pan, the same as all previous versions of AutoCAD
Norman Yuan
64 bit VB app? Mine try to get a point when i pan...
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load Dim picPoint As Object = Nothing Dim oCDwg As AutoCAD.AcadDocument Dim AcadApp As AutoCAD.AcadApplication AcadApp = GetObject(, "AutoCAD.Application") If AcadApp Is Nothing Then AcadApp = CreateObject("AutoCAD.Application") End If AcadApp.Visible = True AcadApp.WindowState = AutoCAD.AcWindowState.acMax oCDwg = AcadApp.ActiveDocument picPoint = oCDwg.Utility.GetPoint(, "Välj första punkt: ") End Sub
It looks like you are doing AutoCAD auotmation from an external EXE app. In this case, it has nothing to do with either AutoCAD or your app being 32 or 64 bit app.
Again, it works for me with an WinForm exe app and AutoCAD2015: I can pan/zoom when AutoCAD is waiting for picking a point/an entity:
using System; using System.Windows.Forms; using AutoCAD; namespace AcadAutomation { public partial class Form1 : Form { private AutoCAD.AcadApplication _cadApp = null; public Form1() { InitializeComponent(); } private void StartAutoCAD() { if (_cadApp==null) { _cadApp = new AcadApplicationClass(); } _cadApp.WindowState = AutoCAD.AcWindowState.acMax; _cadApp.Visible = true; } private void PickPointInAutoCAD() { AcadDocument dwg = _cadApp.ActiveDocument; double[] centre=new double[]{1.0,1.0,0.0}; dwg.ModelSpace.AddCircle(centre, 5.0); try { dwg.Utility.GetPoint(Type.Missing, "\nSelect a point:"); } catch { } try { object ent; Object pt; dwg.Utility.GetEntity(out ent, out pt, "\nSelect an entity:"); } catch { } } private void Form1_Load(object sender, EventArgs e) { StartAutoCAD(); PickPointInAutoCAD(); } } }
Norman Yuan
Tryed on 3 different computers with new 2015 install, same problem. Scroll button gives "invalid point" not pan. Might there be a setting for this? Went back to 2014, works perfectly!
