Steve,
I headed down the VBA road from LISP a while back. Looking
back I should have gone with C++ and ARX, but needed to get
up and running fast and for me that meant VBA.
If you're C++ inclined go with native ARX for what you need, but it's
it not a simple matter of a month of power coding and you're up
and running. I've been at it over a year and still a novice at best, but
that's just me. For resources I bought the books "Object ARX Primer"
by Bill Kramer, "Programming AutoCAD2000 Using ObjectARX" by
Charles McAuley. I also got Ransen's ObjectARX Course which is
a video tutorial, I prefer the books. Once you get going it's not as bad
as it first seems, you just need to get over all the scary big names..:)
Start reading all the posts current and past in the ARX group and you'll
learn lots. Do not try use them as a C++ learning resource, there are
many other groups for that. Note - this is avialible for all versions of
AutoCAD, but is version dependent. You need the right compiler for
the version of AutoCad you're coding aganist.
Lastly is ARX dotnet has been available since 2005, which I did not use but
have read it was not very complete then. There is a pdf which will get you
up and running (much quicker than native ARX IMO but I'm a bit thick
at times) available on the dotNet group. I do not know what access to
Solid data is available and have not tired. Lot of brains over at both of
those
groups who willingly help those who help themselves..ie learn the language
before jumping into the API. I started backwards and quickly got slapped
back down to learning dotnet before I jumped back in, as I should have. This
language is not compiler version dependent. Notepad works fine if you don't
have any need for your sanity. You can use the Express versions available
from
MS to get started.
The gap is closing between between native and managed ARX but the pros
seem to say that native is still the way to go for full power and speed. As
for your
needs, it depends on the complexity of the app you're witting? I would
go to each of these groups and start reading. The native ARX group will keep
you
reading for a looooog time...The managed ARX group(dotnet) is newer so
there is not nearly the threads available.
Maybe the the experts will chime in. Good luck and be tenacious! It's just
code
gl - Paul
wrote in message news:5136316@discussion.autodesk.com...
Hi Paul
Thanks for the help
I'd like to go deeper in programming AutoCAD you seem to no more about it.
I'm not sure what road to follow vba, vb.net or C++ can you help me in
making this decision?
Steve
