I got some of this code from the help. Some of this code I had from other things I did years ago so it's probably not correct.
I am using AutoCAD 2000i BTW
I would like to click a button, hide the form, pick the text, I'm only picking one text item, then insert the picked text into a block. Then put the text into the attribute in the block
Insertion point of the block next to the text item.
Private Sub CommandButton2_Click()
frmGetData.Hide
'Set sset = ThisDrawing.SelectionSets.Add("SS3")
Set sset = ThisDrawing.PickfirstSelectionSet
sset.SelectOnScreen
'For Each ssobject In sset
'msg = msg & vbCrLf & ssobject.ObjectName
'Next ssobject
'MsgBox "The Pickfirst selection set contains: " & msg
'sset.SelectOnScreen
' get text from text entity
' insert block
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "myBlock", 1#, 1#, 1#, 0)
' attributes for the block reference
varAttributes = blockRefObj.GetAttributes
varAttributes(0).TextString = textfromTextEntity
blockRefObj.Update
' end block stuff
'ThisDrawing.SelectionSets("SS3").Delete 'to delete the existing selection set
frmGetData.Show
End sub
TIA
Try to adapt this code to your suit:
Here is very quick and dirty example
Change it as you need
Option Explicit
Private Sub cmdSelect_Click()
Dim oEnt As AcadEntity
Dim oText As AcadText
Dim oAttrib As AcadAttribute
Dim oBlkRef As AcadBlockReference
Dim oBlkDef As AcadBlock
Dim ppt As Variant
Me.Hide
ThisDrawing.Utility.GetEntity oEnt, ppt, vbCrLf & "Select text:"
If Not TypeOf oEnt Is AcadText Then
MsgBox "You have to select single-line text only"
Exit Sub
Set oText = oEnt
Me.TextBox1.Text = oText.TextString
Set oEnt = Nothing
ThisDrawing.Utility.GetEntity oEnt, ppt, vbCrLf & "Select block:"
If Not TypeOf oEnt Is AcadBlockReference Then
MsgBox "You have to select block reference text only"
Exit Sub
Set oBlkRef = oEnt
Dim ins As Variant
ins = oBlkRef.insertionPoint
ins = ThisDrawing.Utility.TranslateCoordinates(ins, acUCS, acWorld, False)
ppt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Pick location point of attribute: ")
ppt = ThisDrawing.Utility.TranslateCoordinates(ppt, acUCS, acWorld, False)
Dim xgap As Double
Dim ygap As Double
xgap = CDbl(ppt(0)) - CDbl(ins(0))
ygap = CDbl(ppt(1)) - CDbl(ins(1))
Dim blkname As String
blkname = oBlkRef.EffectiveName
Dim aTag As String, aPrompt As String, aValue As String
Me.TextBox2.Text = blkname
Dim aHgt As Double
Dim aMode As Long
Dim ipt(0 To 2) As Double
' define the attribute definition
aHgt = oText.height
aMode = acAttributeModeVerify
aPrompt = "My Prompt"
aTag = "New Tag"
aValue = "New Value"'<-- or set value from TextBox1.Text
Set oBlkDef = ThisDrawing.Blocks(blkname)
Dim orig As Variant
orig = oBlkDef.origin'<-- already in WCS
ipt(0) = CDbl(orig(0)) + xgap: ipt(1) = CDbl(orig(1)) + ygap: ipt(2) = 0
' add the attribute definition object in the block table record
Set oAttrib = oBlkDef.AddAttribute(aHgt, aMode, aPrompt, ipt, aTag, aValue)
ThisDrawing.SendCommand "_attsync N " & blkname & vbCr
Unload Me
End Sub
