Hello all,
Right now my code will plot all P and L named views in a drawing (i.e. L1,
L2, etc.). However, I was able to populate a ListBox with the View names,
however, I cannot get the "names" of the selected items passed correctly to
my PlotView sub.
In UserForm Initialize to populate the ListBox (with Multiple selection
enabled) with the VIEW names:
For Each objView In objViews
strView = objView.Name
If strView Like "L#" Or strView Like "L##" Or strView Like "P#" Or
strView Like "P##" Then
lstViews.AddItem objView.Name
Next objView
Button on the form calls this sub.
Public Sub PlotAllViews(pltMode As String)
Dim objView As AcadView
Dim objViews As AcadViews
Dim strView As String
Dim i As Integer
Set objViews = ThisDrawing.Views
strView = Mid(strView, 2)
intView = Val(strView)
PlotView objView, pltMode
Next objView
End Sub
However, I am trying to work this code into the PlotAllViews sub, so that
ONLY the selected views in the ListBox are passed to the PlotView objView,
pltMode line. I don't need my L and P string check anymore because I am
doing that when the form initializes.
Dim i As Integer
If lstViews.ListIndex = -1 Then Exit Sub
For i = lstViews.ListCount - 1 To 0 Step -1
If lstViews.Selected(i) = True Then
Debug.Print lstViews.List(i)
Next i
