VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Monochrome.ctb Plots Grayscale Not Black And White
1 REPLY 1
cascadtx
716 Views, 1 Reply
I am setting a paper space layout tab to plot PostScript to a file with the monochrome.ctb plot style, and the setting seems to be 'taking', but the plots come out gray scale rather than monochrome or even color.  Plotting through the PLOT command dialog using monochrome.ctb yields the desired result.  Below is the relevant code and comments.
  ' objStartDoc is an empty drawing used simply to create the PlotConfiguration to be copied
  objStartDoc.ActiveSpace = acPaperSpace
  objStartDoc.ActiveLayout.RefreshPlotDeviceInfo
  Set objPlotCfgA4 = objStartDoc.PlotConfigurations.Add("A4", False)
  With objPlotCfgA4
    .ConfigName = "Xerox 6204 Wide Format PS3 File"
    .CanonicalMediaName = "A4"
    .PlotType = acLayout
    .GetPlotDeviceNames
    '.CenterPlot = True
    .PaperUnits = acInches
    .SetCustomScale 1#, 1#
    .GetPlotDeviceNames
    .PlotRotation = ac270degrees
    .PlotViewportBorders = False
    .PlotWithLineweights = True
    .PlotWithPlotStyles = False
    .ScaleLineweights = False
    .StyleSheet = "monochrome.ctb"
    .GetPlotStyleTableNames
  End With    ' objPlotCfgA4
  ' I don't remember why I did this or if it is even necessary
  objStartDoc.ActiveLayout.CopyFrom objPlotCfgA4
  objStartDoc.Regen acAllViewports
    ' vntName is the fully qualified path to the drawing file I want to plot
    Set objDoc = _
        Application.Documents.Open(VBA.CStr(vntName), True)
    If Not (Application.ActiveDocument Is objDoc) Then
      Application.ActiveDocument = objDoc
    objDoc.ActiveLayout.RefreshPlotDeviceInfo
    '  strLOName is the name of a paperspace layout in the drawing
      Set objLO = objDoc.Layouts.Item(strLOName)
      objDoc.ActiveLayout = objLO
      strPgSize = objLO.CanonicalMediaName
      LL = objDoc.GetVariable("LIMMIN")
      ReDim Preserve LL(0 To 1)
      UR = objDoc.GetVariable("LIMMAX")
      ReDim Preserve UR(0 To 1)
        With objPlotCfgA3
          .SetWindowToPlot LL, UR
          .PlotType = acWindow
          .CenterPlot = True
          objLO.CopyFrom objPlotCfgA3
          ' I don't know why I thought I needed to set plot to window above, then back to layout here
        End With
      objDoc.ActiveLayout = objDoc.Layouts.Item("Model")
      objDoc.SetVariable "BACKGROUNDPLOT", 0
      Set objPlot = objDoc.Plot
      ' Debug mode indicates objDoc.ActiveLayout.StyleSheet = monochrome.ctb at this point
      With objPlot
        .NumberOfCopies = 1
        strTmp = "Blah"  ' The output name for the 'Print To File' PostScript .plt file
        On Error Resume Next
        blnPlotSucc = .PlotToFile(strTmp)
        On Error GoTo 0
      End With
Tags (1)
1 REPLY 1
cascadtx
in reply to: cascadtx
The problem was the following line:
needs to be
.PlotWithPlotStyles = True
”Boost
