I am setting a paper space layout tab to plot PostScript to a file with the monochrome.ctb plot style, and the setting seems to be 'taking', but the plots come out gray scale rather than monochrome or even color. Plotting through the PLOT command dialog using monochrome.ctb yields the desired result. Below is the relevant code and comments.
' objStartDoc is an empty drawing used simply to create the PlotConfiguration to be copied
objStartDoc.ActiveSpace = acPaperSpace
objStartDoc.ActiveLayout.RefreshPlotDeviceInfo
Set objPlotCfgA4 = objStartDoc.PlotConfigurations.Add("A4", False)
With objPlotCfgA4
.ConfigName = "Xerox 6204 Wide Format PS3 File"
.CanonicalMediaName = "A4"
.PlotType = acLayout
.GetPlotDeviceNames
'.CenterPlot = True
.PaperUnits = acInches
.SetCustomScale 1#, 1#
.GetPlotDeviceNames
.PlotRotation = ac270degrees
.PlotViewportBorders = False
.PlotWithLineweights = True
.PlotWithPlotStyles = False
.ScaleLineweights = False
.StyleSheet = "monochrome.ctb"
.GetPlotStyleTableNames
End With ' objPlotCfgA4
' I don't remember why I did this or if it is even necessary
objStartDoc.ActiveLayout.CopyFrom objPlotCfgA4
objStartDoc.Regen acAllViewports
' vntName is the fully qualified path to the drawing file I want to plot
Set objDoc = _
Application.Documents.Open(VBA.CStr(vntName), True)
If Not (Application.ActiveDocument Is objDoc) Then
Application.ActiveDocument = objDoc
End If
objDoc.ActiveLayout.RefreshPlotDeviceInfo
' strLOName is the name of a paperspace layout in the drawing
Set objLO = objDoc.Layouts.Item(strLOName)
objDoc.ActiveLayout = objLO
strPgSize = objLO.CanonicalMediaName
LL = objDoc.GetVariable("LIMMIN")
ReDim Preserve LL(0 To 1)
UR = objDoc.GetVariable("LIMMAX")
ReDim Preserve UR(0 To 1)
With objPlotCfgA3
.SetWindowToPlot LL, UR
.PlotType = acWindow
.CenterPlot = True
objLO.CopyFrom objPlotCfgA3
' I don't know why I thought I needed to set plot to window above, then back to layout here
End With
objDoc.ActiveLayout = objDoc.Layouts.Item("Model")
objDoc.SetVariable "BACKGROUNDPLOT", 0
Set objPlot = objDoc.Plot
' Debug mode indicates objDoc.ActiveLayout.StyleSheet = monochrome.ctb at this point
With objPlot
.NumberOfCopies = 1
strTmp = "Blah" ' The output name for the 'Print To File' PostScript .plt file
On Error Resume Next
blnPlotSucc = .PlotToFile(strTmp)
On Error GoTo 0
End With
