VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
modifying xrefs path and filename
10 REPLIES 10
Message 1 of 11
613 Views, 10 Replies
I am trying to modify the xref block filename and path. I have written a
routine that will grab all blocks that are xrefs but I cannot figure out how
to incorporate the externalreference object. Every example I find loads the
xref with the code. I am trying to modify the xref path and file name of an
xref that has already been loaded. Any suggestions.
Dim xref_file As AcadExternalReference
For x = 0 To Me.Blocks.Count - 1
If Me.Blocks(x).IsXRef Then
'Set xref_file = Me.Blocks.Item(Me.Blocks(x).Name).Reload
'The line above is what I am having trouble with.
'I cannot figure out how to attach the object to the xref_file
'variable.
End If
Next x
10 REPLIES 10
Message 2 of 11
Jorge,
Set xref_file = Me.Blocks.Item(x)
Joe Sutphin
Visual Basic How-To For AutoCAD
for more book details click on the link
http://eomnisource.hypermart.net
"Jorge Aguirre" wrote in message news:90480FA55016B5A448665C6E2D85C392@in.WebX.maYIadrTaRb...
> 'variable.
> End If
> Next x
Message 3 of 11
I have tried this. I get an error message, run-time error '13' Type
mismatch.
Thank You for your response
Jorge Aguirre
"Joe Sutphin" wrote in message
news:B78BCC21DF8001E95213AC39FA18A976@in.WebX.maYIadrTaRb...
> Jorge,
> Joe Sutphin
a
how
the
of an
> > 'variable.
> > End If
> > Next x
Message 4 of 11
how
the
an
VBA does not have access to the path of an external
reference, so you will have to use a third-party tool.
You can visit www.caddzone.com/acadx/acadx.htm and get
a copy of AcadX.arx, which provides several ways to do
this (one at a time, or all at once).
See the ReplaceXRefPaths() function in AcadXDatabase,
or the XRefPath property of the AcadXUtility object.
Message 5 of 11
Public Sub GetXref()
Dim oXref As AcadExternalReference
Dim acObject As AcadObject
For Each acObject In ThisDrawing.ModelSpace
If TypeOf acObject Is AcadBlockReference Then
If ThisDrawing.Blocks(acObject.Name).IsXRef Then
Set oXref = acObject
End If
End If
Next acObject
MsgBox oXref.Path
End Sub
Joe Sutphin
Message 6 of 11
Contrary to Tony's post, VBA can access the path of an xref just fine. The
trick is getting to the xref. The attached module shows one way to do this.
If your intention is to repath and reload the xref, once you've changed the
xref path be sure to use the blocks collection to reload it:
ThisDrawing.Blocks("x").Reload
Good judgment comes from experience.
Experience comes from bad judgment.
http://www.acadx.com
how
the
an
> 'variable.
> End If
> Next x
Message 7 of 11
This works, thanks. I was cycling through the blocks but never thought to
cycle through the objects.
Jorge
"Frank Oquendo" wrote in message
news:79466AB48F77B79CAB1C41A389E7992C@in.WebX.maYIadrTaRb...
this.
the
a
> how
> the
of
> an
> > 'variable.
> > End If
> > Next x
Attribute VB_Name = "Module1"
Public Sub test()
' Assumes you've referenced COLORWH.DWG in your sample folder.
' Move COLORWH.DWG to your TEMP folder before running.
Dim ss As AcadSelectionSet, fType, fData
Dim xref As AcadExternalReference
Set ss = CreateSelectionSet
BuildFilter fType, fData, 0, "INSERT", 2, "COLORWH"
ss.Select acSelectionSetAll, , , fType, fData
For Each xref In ss
xref.Path = "C:\Temp\colorwh.dwg"
ThisDrawing.Blocks(xref.Name).Reload
Next
End Sub
Public Sub BuildFilter(typeArray, dataArray, ParamArray gCodes())
Dim fType() As Integer, fData()
Dim index As Long, i As Long
index = LBound(gCodes) - 1
For i = LBound(gCodes) To UBound(gCodes) Step 2
index = index + 1
ReDim Preserve fType(0 To index)
ReDim Preserve fData(0 To index)
fType(index) = CInt(gCodes(i))
fData(index) = gCodes(i + 1)
Next
typeArray = fType: dataArray = fData
End Sub
Public Function CreateSelectionSet(Optional ssName As String = "ss") As
AcadSelectionSet
On Error Resume Next
Set ss = ThisDrawing.SelectionSets(ssName)
If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
ss.Clear
Set CreateSelectionSet = ss
End Function
Message 8 of 11
how
the
an
Sorry, my mistake. You can get at the Path of an XRef from
VBA.
However, the way that several others have suggested doing it
is wrong, because it iterates over the Xrefs, and there can
be any number of insertions of the same xref in a drawing,
in which case, the code repeatedly changes the path of and
reloads the same xref multiple times.
Use a dictionary or collection to store the name of each
xref you have already visited, and you can use it to avoid
changing the path and reloading it multiple times.
Message 9 of 11
Good point!
Joe
Tony Tanzillo wrote in message
news:71946B8D8F47A996C64B28E557E80A39@in.WebX.maYIadrTaRb...
a
> how
> the
of
> an
> VBA.
Message 10 of 11
This can be simple accomplished without Collection or dictionaries just by
checking the current path to the new path.
Sudo code:
If isXref(x) then
if x.path <> YourPath then
x.path = Yourpath
end if
end if
| Rob Starz
| Stardsign cad solutions
| iC - AEC Information Center
| www.stardsign.com/aecic.html
| free ADT and Building Systems tools
| *******LayerX available Now*************
| www.stardsign.com/layerx.htm
| Easter Egg Hunt.....win a free version of LayerX
Message 11 of 11
A dictionary/collection is unnecessary. All you need to do is process the
first item in the returned selection set.
”Boost
