VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
method 'getentity' of object 'iacadutility' failed when
0 REPLIES 0
Message 1 of 1
483 Views, 0 Replies
Updating VBA code from AutoCAD 2011 to 2015. In one particular macro it should prompt for the user to pikc a Polyline. It never propmpts and finishes with the error trap. I get the error "method 'getentity' of object 'iacadutility' failed " when commenting out the "On Error Resume Next". What has changed since 2011 that would cause this?
    AreaBlockchk = False
    oDocB.Utility.GetEntity returnObj, basePnt, "Please select a desired Area POLYLINE to process:"
    ZoomExtents
    If Err <> 0 Then
        MsgBox "Either no POLYLINE was selected, or the routine has been canceled.", vbCritical + vbExclamation, "CT-Error"
        oDocA.Close False
        oDocC.Close False
        Exit Sub
0 REPLIES 0
ā€Boost
