VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Assem_m1
191 Views, 4 Replies
Menu
hi
how I can make my macro autostart and create new menu to open Macro
from out AutoCAD (like install file )
4 REPLIES 4
ml0940
in reply to: Assem_m1
Assem
Can you be a bit more specific?
What preciselty are you trying to do?
ML
Assem_m1
I try to mack install file for my macro
this install load my macro in AutoCAD and create menu to run the macro
" like Express tools "
kashi_rock
For this purpose, you need to create a menu file then create a cui file with created menu. Now make a lisp routine so that you can add your defined menu to the autocad menubar. Now whenever you required your macro to run from the drop down menu you can just load that lisp routine. Have a look to attached files. Hope it will help you.
Kaushal
Assem_m1
thank you Kaushal
”Boost
