VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Measure or divide command in vba
4 REPLIES 4
1847 Views, 4 Replies
I want to insert a block along a polyline like measure or divide command. Is there a way to use these commands in vba ? Sukru Baykan
4 REPLIES 4
Also need this functionality but looking at other posts, it seems you have to use LISP.
first of all
you need to insert block command I send an example...
then you specified the coords. of the where the block inserted.
along a polyline I suggest get coordinate method.
if you describe your problem with details, I can help with further imformation.
here is insert block example which already existed in acad
sub is add block to (0,0,0) coordinate, you can modfiy to polyline coordinates..
Sub block_ekleme()
    Dim blocknesnesi As AcadBlockReference
    Dim kesisim(0 To 2) As Double
    kesisim(0) = 0: kesisim(1) = 0: kesisim(2) = 0
    Set blocknesnesi = ThisDrawing.ModelSpace.InsertBlock(kesisim, "blo", 1#, 1#, 1#, 0)
    ZoomAll
End Sub
it is fairly easy to do mathematically. Here is one example. It is maybe little complex 🙂 but will give you directions how to do it. There is a way with SendCommand() method but I don't know how it works. Look in Help Menu there is plenty of examples
 Nice job, however if a segment of poly line is arc you measure the distance of the cord not the real distance on curve.
”Boost
