I have a VBA routine that allows the user to select multiple drawing files to be processed.If the user selects several files this can be a lengthy process. There is no espace without shutting down AutoCAD altogther. Is there a way to create an escape from my loop.
Sub SelectManyFiles()
'Get list of drawings
If FileList.Count > 0 Then
With FileList
For i = 1 To .Count
'Need an escape here
dwgName = .Item(i)
If Dir(dwgName) <> "" Then
FileSystem.SetAttr (dwgName), vbNormal
Application.Documents.Open dwgName
ThisDrawing.Close False
Next
End With
End Sub
Thanks for any input.
Solved by norman.yuan. Go to Solution.
just place an
exit for
as a consequence of a check that you must implement.
for instance you could track the time elapsed from the beginning of your "For-Next" loop and decide to "exit for" if it reaches a limit time
on the other hand if you already know a limit file number to process, than you can place an "If" statement before the "For-Next" loop
bye
I want the user to have the ablitty to abort the routine.How do I get ot to invoke from esc key or function key.
Sorry but never faced such a need
I'd try and solve it two ways:
1) anytime your loop starts a new iteration you make a form appear for only a few second showing a button to let the user abort the routine. you may want to make the form appear on every definite time interval elapsing
2) event handlers, such as clicking somewhere in the drawing
I tried a modeless userform it kind of works in 2007. 2007 does not show the whole form but does you can click on the red X and close out. In 2010 if I go modeless I have no control at alll until the operation is complete. I am unfarmillar with a click event in the drawing itself.
Are you using AutoCAD 2010 32-bit or 64-bit?
Using VBA modeless form is, in general, not a good choice, or a necessary choice. Did you added AcFocus control tothe form?
If your AutoCAD 2010 is 64-bit, things likely got worse because of the fact that VBA reains as 32-bit out-process part, which may make modeless form event nmore difficult to control.
For a btach process like opening/closing a list of drawing files in AutoCAD, it should not be a problem with modal form, and you can easily stop the loop by clicking a button or hit Esc key, if the code is written correctly.
Norman Yuan
So I tried running everthing from the user form, now the dialog does not show up until the batch operation is complete.
Well, without seeing your code, it is hard to tell where you did is wrong. But ot is fairly simple to run a batch from a modal form and to stop the process.
Following is the code to do this (A simple form with 2 buttons on it: "Start" and "Stop"):
The macro code:
Option Explicit Public Sub BatchTest() UserForm1.Show End Sub
The form code:
Option Explicit Private files() As String Private Const FILE_FOLDER As String = "C:\Temp" Private stopped As Boolean Private app As AutoCAD.AcadApplication Private Sub cmdStart_Click() cmdStart.Enabled = False cmdStop.Enabled = True stopped = False Dim i As Integer For i = 0 To UBound(files) lblDrawing.Caption = files(i) DoEvents If stopped Then Exit For processDrawing FILE_FOLDER & "\" & files(i) Next cmdStart.Enabled = True cmdStop.Enabled = False lblDrawing.Caption = "" If i < UBound(files) Then MsgBox "Processing was stopped before completion!" Else MsgBox "Processing completed!" End If End Sub Private Sub cmdStop_Click() stopped = True End Sub Private Sub processDrawing(fileName As String) Dim dwg As AcadDocument Set dwg = app.Documents.Open(fileName) ''Do something this this document dwg.Close False End Sub Private Sub UserForm_Initialize() Set app = ThisDrawing.Application ''Assume there are a list of file names already available ReDim files(4) files(0) = "Test1.dwg" files(1) = "Test2.dwg" files(2) = "Test3.dwg" files(3) = "Test4.dwg" files(4) = "Test5.dwg" End Sub
As you can see. there is NO WAY the fialog box not showing until after the processing: the dialog fomr MUST show first so that the process can start (by clicking the "Start" button.
The trick to allow the click on "Stop" button to be acccepted is to call DoEvents() in the loop.
Norman Yuan
I think my problem was that I did not have a start button. The batch process started from the UserForm_Initialize. Will try again with start button.
If you want the processing starts as soon as the form is shown, then you can start it in the Activate event handler instead of Initialize event handler. Just to make sure the process only runs once (because if you show a messagebox oon top the form, dismiss the message box would cause Activate event fires again). This way, you can only have "Stop" button on the form, and as soon as the process is completed or stopped, the form is unloaded.
You may also handle Form_QueryClose event to prevent user from closing the form accidently by clicking "x" on upper-right corner.
Norman Yuan
thanks ricvba - it seems that with civil 3d you can right-click and generate a boundary... which is an AEC Polygon and doing intersects with that works. Not sure yet how to just test for overlaping intersections and not include touching intersections...
