VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
LINKING EXCEL WITH ACAD BLOCKS
22 REPLIES 22
Message 1 of 23
1957 Views, 22 Replies
Is there a simple way to assign attributes blocks using an Exel reference?
I've attached a dwg with a block that has different pieces of info on it. I'd like to just put the Detail Reference in and then run a VBA and it would put the rest of the info in for me by referencing an Excel spreadsheet. That way I can set up the formulas on the spreadsheet and let VBA fill in the attributes.
22 REPLIES 22
Message 21 of 23
I figured it out....
I updated the spreadsheet to filename.xlsx
That way the type library matched the file in use.
I'll play with it now and get back to you. THANKS!!!!
M Message was edited by: MikeENGHome
Message 22 of 23
I guessroblem is on your Excel version
Try to change this line:
Set ObjExcel = CreateObject("Excel.Application.11")
on another one
Set ObjExcel = CreateObject("Excel.Application.12")'<--I am not sure about
I don't know exactly what the numeric version
will be for the Excel 2007
I feel that there is a long deal here
If you want, let you send your opinion
directlly to me fixo@yandex.ru
I'll free on this weekend for programming
~'J'~
Message 23 of 23
hi  can u help me ,
i need to assign a variable say A to  value 5 wich can be set using the (setq a 5 ) in autocad command prompt
but can any one tell me how can i assign it thru  excell vba code  plse and soon
”Boost
