jarodriguez@jet.es says...
> What happens when the original block has more than 1 layer?
Only the blockreference, itself, gets placed on the layer. It is the
same as if you inserted the block manually and then changed its layer
property.
> And, what if the layer names of the original block are not
> present in the drawing?
They get created just as if you inserted the block manually.
Mike Tuersley
PhD @ CADalyst's AutoCAD Clinic
http://www.cadonline.com
