VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
layer transparant
4 REPLIES 4
210 Views, 4 Replies
layer transparant
I would like to insert block on the picked layer and then go back to the
active layer in my drawing ( a sort of transparant command).
Can sambody please help me?
Here is the code with layers i got so far.....
Private Sub ComboBox2_Click()
Dim PickLayer As String
Dim NewLayer As AcadLayer
PickLayer = ComboBox2.Text
Set NewLayer = ThisDrawing.Layers(PickLayer)
Unload Me
ThisDrawing.ActiveLayer = NewLayer
End Sub
Private Sub UserForm_Initialize()
Dim entry As AcadLayer
For Each entry In ThisDrawing.Layers
ComboBox2.AddItem entry.Name
Next
End Sub
Thanx in advance!
4 REPLIES 4
Hi Suky,
Don't bother to change layers.
Simply assign the new layer to the block reference.
"suky" wrote in message
news:87D48A569203F085B02C00A11550553B@in.WebX.maYIadrTaRb...
> Unload Me
> ThisDrawing.ActiveLayer = NewLayer ** Not needed
Somewhere use:
blockreference.layer = NewLayer
> End Sub
> Next
> End Sub
> Thanx in advance!
Thanx Laurie 🙂
"Laurie Comerford" schreef in bericht
news:A83F2701562A7D91A901FB4EF054CBE1@in.WebX.maYIadrTaRb...
> Hi Suky,
> > Unload Me
> Somewhere use:
> > End Sub
> > Next
> > End Sub
> > Thanx in advance!
What happens when the original block has more than 1 layer? And, what if the
layer names of the original block are not present in the drawing?
Laurie Comerford ha escrito:
> Hi Suky,
> > Unload Me
> Somewhere use:
> > End Sub
> > Next
> > End Sub
> > Thanx in advance!
jarodriguez@jet.es says...
Only the blockreference, itself, gets placed on the layer. It is the
same as if you inserted the block manually and then changed its layer
property.
> And, what if the layer names of the original block are not
They get created just as if you inserted the block manually.
Mike Tuersley
PhD @ CADalyst's AutoCAD Clinic
http://www.cadonline.com
”Boost
