VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
LaunchBrowserDialog
3 REPLIES 3
245 Views, 3 Replies
LaunchBrowserDialog
Hello All,
I am trying to use the LaunchBrowserDialog function to load the "New Email"
dialog from a form within VBA.
Here is my code:
ThisDrawing.Utility.LaunchBrowserDialog "", "", "",
"mailto:someone@thisplace.com", "", True
The above code works well enough to launch the default "New E-mail"
dialog... but it still loads the browser in the background. Is there a way
to prevent the browser from loading in this instance?
Also, when the browser does load... it loads the AutoCAD browser... is there
a way to get the "default" (IE?) browser to load instead? I assume it has
something to do with placing the proper browser registry name in the
ReigstryRootKey property, but I don't know what that might be.
TIA,
Rob
3 REPLIES 3
Rob Outman had this to say
> is there a way to get the "default" (IE?) browser to load instead?
http://code.acadx.com/howto/vb/default_browser.htm
There are 10 kinds of people:
Those who understand binary and those who don't
http://www.acadx.com
Why am I not surprised that you already had something to resolve this issue
Frank! 🙂
Thanx,
Rob
"Frank Oquendo" wrote in message
news:A9B48F8B9B6CACD02BFA965C373E139E@in.WebX.maYIadrTaRb...
bcoward
Rob,
You could also add the ShellExecute API as an alternative to trying to figure out what your default browser is.
To start your default browser and view a particular Web site:
Call ShellExecute(Me.hwnd, "open", "www.AutoDesk.com", "", 0, SW_SHOWNORMAL)
Good luck,
Bob Coward
CADS, Inc
www.cadsinc.com
”Boost
