Hello
I have many short lwplines on separate layers. I need to join them by layer and then add fit or spline smoothing depending on if they are closed or open. The plines are produced automaticaly in code, so there is nothing else on the layers besides the pline. I am using this code to create a selection set of plines for each layer.
' ' ' If sset Is Nothing Then Set sset = ThisDrawing.SelectionSets.Add("ss1") End If lifiltertype(0) = 8 v(0) = "jhl_11.00_begin" sset.Select acSelectionSetAll, , , lifiltertype, v
I think that I have to use SendCommand to do this. I would like to know the proper syntax to Join, Fit or Spline the plines using my selection set.
Thank you
John
Solved by john1951. Go to Solution.
I'm working now on creating a method for joining polylines in VBA. I think that I have to use SendCommand method to do this. So here are some tips how you can do that. Using PEDIT command with SendCommand method, gives you option to add objects to join by one of this methods: Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle. I'm using Group to join objects. First I creat Group and then I add objects to it. Then with SendCommand I join them in single polyline.
Dim oLWP As AcadLWPolyline
Dim i As Long
Dim var As Variant
Dim oSS() As AcadEntity
Dim oGr As AcadGroup
Set oGr = ThisDrawing.Groups.Add("QWERT")
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("Sa1")
sset.SelectOnScreen
' here you use your selectin set
i = 0
For Each var In sset
Set oLWP = var
ReDim Preserve oSS(i)
Set oSS(i) = oLWP
i = i + 1
Next
' add objects t\o the group
oGr.AppendItems oSS
Dim GRname As String
GRname = oGr.Name
' using SendCommand method with Group
ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "J" & vbCr & "0.0" & vbCr & vbCr
' deleting group and selection set
oGr.Delete
sset.Delete
About FIT and SPLINE you can use again PEDIT with SendCommand method:
' FIT
ThisDrawing.SendCommand "_PEDIT" & vbCr & "F" & vbCr & vbCr
' SPLINE
ThisDrawing.SendCommand "_PEDIT" & vbCr & "S" & vbCr & vbCr
but selecting pline to fit or spline is difficult. Easily you can find that pline is closed or not with oLWP.Closed property. But selecting them is difficult. Methods are: Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon (you can view them by write "?" in command line when command asking you to select objects). I think that if you add all closed plines in one Group and others in second you can use then first method with Group to edit plines.
Hello
This is exactly what I need to know. I never heard of Group before. I am going to try this right now.
Many thanks
John
I forgot for this option. WHen you use lines or different objects the AutoCAD will ask you do you want to convert the objects to polylines. Use this variable PEDITACCEPT and set it to 1. Then the program will convert them without asking you.
Hello
Here is some code that seems to work, includes Join Spline and Fit
Private Sub CommandButtonSmooth_Click() Dim sset As AcadSelectionSet Dim v(0) As Variant Dim lifiltertype(0) As Integer Dim plineObj As AcadLWPolyline Dim oLWP As AcadLWPolyline Dim i As Long Dim var As Variant Dim oSS() As AcadEntity Dim oGr As AcadGroup Set oGr = ThisDrawing.Groups.Add("QWERT") Set sset = Nothing For i = 0 To ThisDrawing.SelectionSets.Count - 1 Set sset = ThisDrawing.SelectionSets.Item(i) If sset.Name = "ss1" Then sset.Clear Exit For Else Set sset = Nothing End If Next i If sset Is Nothing Then Set sset = ThisDrawing.SelectionSets.Add("ss1") End If 'create a selection set of all the entities on a given layer 'here they are all lw polylines lifiltertype(0) = 8 v(0) = "jhl_9.25_begin" sset.Select acSelectionSetAll, , , lifiltertype, v ReDim Preserve oSS(0 To sset.Count - 1) As AcadEntity For i = 0 To sset.Count - 1 Set oSS(i) = sset.Item(i) Next i 'add plines to group oGr.AppendItems oSS Dim GRname As String GRname = oGr.Name ' using SendCommand method with Group ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "J" & vbCr & "0.0" & vbCr & vbCr ' deleting group and clearing selection set oGr.Delete sset.Clear 'start to pedit spline or fit here Dim oGroup As AcadGroup Set oGroup = ThisDrawing.Groups.Add("ZERO") GRname = oGroup.Name 'select all the joined plines sset.Select acSelectionSetAll, , , lifiltertype, v ReDim Preserve oSS(0) As AcadEntity For i = 0 To sset.Count - 1 Set oLWP = sset.Item(i) Set oSS(0) = sset.Item(i) 'create group with one item oGroup.AppendItems oSS If oLWP.Closed Then 'Spline ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "S" & vbCr & vbCr Else 'Fit ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "F" & vbCr & vbCr End If 'remove the pline from the group oGroup.RemoveItems oSS Next i sset.Delete oGroup.Delete End Sub
The code shown has the sub name for a Button control on a form. Just change the name to something that suits you and run the code.
Go to this link at AUGI and read the first post. There are some tutorials I wrote on how to get started with VBA. VBA Lesson 1 explains what you need.
