VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Joining lwpolylines with vba
10 REPLIES 10
Message 1 of 11
5043 Views, 10 Replies
Hello
I have many short lwplines on separate layers. I need to join them by layer and then add fit or spline smoothing depending on if they are closed or open.  The plines are produced automaticaly in code, so there is nothing else on the layers besides the pline.  I am using this code to create a selection set of plines for each layer.
If sset Is Nothing Then
    Set sset = ThisDrawing.SelectionSets.Add("ss1")
End If
lifiltertype(0) = 8
v(0) = "jhl_11.00_begin"
sset.Select acSelectionSetAll, , , lifiltertype, v
I think that I have to use SendCommand to do this.  I would like to know the proper syntax to Join, Fit or Spline the plines using my selection set.
Thank you
John
10 REPLIES 10
Message 2 of 11
I'm working now on creating a method for joining polylines in VBA. I think that I have to use SendCommand method to do this. So here are some tips how you can do that. Using PEDIT command with SendCommand method, gives you option to add objects to join by one of this methods: Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle. I'm using Group to join objects. First I creat Group and then I add objects to it. Then with SendCommand I join them in single polyline.
Dim oLWP As AcadLWPolyline
Dim i As Long
Dim var As Variant
Dim oSS() As AcadEntity
Dim oGr As AcadGroup
Set oGr = ThisDrawing.Groups.Add("QWERT")
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("Sa1")
sset.SelectOnScreen
' here you use your selectin set
i = 0
For Each var In sset
Set oLWP = var
ReDim Preserve oSS(i)
Set oSS(i) = oLWP
i = i + 1
Next
' add objects t\o the group
  oGr.AppendItems oSS
Dim GRname As String
GRname = oGr.Name
' using SendCommand method with Group
ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "J" & vbCr & "0.0" & vbCr & vbCr
' deleting group and selection set
oGr.Delete
sset.Delete
About FIT and SPLINE you can use again PEDIT with SendCommand method:
    ' FIT
    ThisDrawing.SendCommand "_PEDIT" & vbCr & "F" & vbCr & vbCr
    ' SPLINE
    ThisDrawing.SendCommand "_PEDIT" & vbCr & "S" & vbCr & vbCr
 but selecting pline to fit or spline is difficult. Easily you can find that pline is closed or not with oLWP.Closed property. But selecting them is difficult. Methods are: Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon (you can view them by write "?" in command line when command asking you to select objects). I think that if you add all closed plines in one Group and others in second you can use then first method with Group to edit plines.
Message 3 of 11
Hello
This is exactly what I need to know.   I never heard of Group before.  I am going to try this right now.
Many thanks
John
Message 4 of 11
I forgot for this option. WHen you use lines or different objects the AutoCAD will ask you do you want to convert the objects to polylines. Use this variable PEDITACCEPT and set it to 1. Then the program will convert them without asking you.
Message 5 of 11
Hello
Here is some code that seems to work, includes Join Spline and Fit
Private Sub CommandButtonSmooth_Click()
Dim v(0) As Variant
Dim lifiltertype(0) As Integer
Dim plineObj As AcadLWPolyline
Dim i As Long
Dim var As Variant
Set sset = Nothing
For i = 0 To ThisDrawing.SelectionSets.Count - 1
    Set sset = ThisDrawing.SelectionSets.Item(i)
    If sset.Name = "ss1" Then
        sset.Clear
        Exit For
    Else
        Set sset = Nothing
    End If
Next i
End If
'create a selection set of all the entities on a given layer
'here they are all lw polylines
lifiltertype(0) = 8
v(0) = "jhl_9.25_begin"
ReDim Preserve oSS(0 To sset.Count - 1) As AcadEntity
For i = 0 To sset.Count - 1
    Set oSS(i) = sset.Item(i)
Next i
'add plines to group
oGr.AppendItems oSS
GRname = oGr.Name
' deleting group and clearing selection set
oGr.Delete
sset.Clear
'start to pedit spline or fit here
Dim oGroup As AcadGroup
Set oGroup = ThisDrawing.Groups.Add("ZERO")
GRname = oGroup.Name
'select all the joined plines
ReDim Preserve oSS(0) As AcadEntity
    Set oLWP = sset.Item(i)
    Set oSS(0) = sset.Item(i)
    'create group with one item
    oGroup.AppendItems oSS
    If oLWP.Closed Then
        'Spline
        ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "S" & vbCr & vbCr
    Else
        'Fit
        ThisDrawing.SendCommand "_PEDIT" & vbCr & "M" & vbCr & "G" & vbCr & GRname & vbCr & vbCr & "F" & vbCr & vbCr
    End If
    'remove the pline from the group
    oGroup.RemoveItems oSS
Next i
sset.Delete
oGroup.Delete
End Sub
Message 6 of 11
Automohan
How to use this vba program, please anyone!!!
thanks
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Message 7 of 11
Ed.Jobe
in reply to: Automohan
The code shown has the sub name for a Button control on a form. Just change the name to something that suits you and run the code.
Ed
How to post your code.
Message 8 of 11
Automohan
in reply to: Ed.Jobe
Until now never use vba code, for example how to run lisp code
copy the lisp code to node pad save it to file extension .lsp, then look into the program for "defun C:test" then run the program
"Save Energy"
Message 9 of 11
Ed.Jobe
Go to this link at AUGI and read the first post. There are some tutorials I wrote on how to get started with VBA. VBA Lesson 1 explains what you need.
Ed
Message 10 of 11
Automohan
I know this match Visual Basic as explain in the video
Can anyone show me an video that how to use that code
"Save Energy"
Tags (2)
Message 11 of 11
Automohan
attached screencast
"Save Energy"
”Boost
