VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
is there a way to import custom vba's from microstation to acad2011
1 REPLY 1
chris.bird
298 Views, 1 Reply
I have multiple vba's written for microstation and I was wondering if there is a way to import them into acad2011.
Are there any similarities between the two pltforms in regards to vbas?
1 REPLY 1
TerryDotson
in reply to: chris.bird
In Microstations VBA IDE you should be able to export the code to FRM/FRX and BAS files.  These files could then be imported in AutoCAD's VBA IDE.  Then comes the problems:
First, there are bound to be procedures specific to getting/creating objects and more that are MSTA specific.  Those will have to be changed to accomodate the differences in AutoCAD.  It won't be as simple at export/import.
Second, unless you plan to stay with 2011/2012 forever, why bother.  It is rumored (or possibly stated) that Autodesk will remove VBA at some point in the near future.
In summary the best choice would be a complete rewrite using the Managed .NET API.  This would provide the conversion with an actual future and result in a better, faster application.
”Boost
