Can somebody please help me with this problem?
I'm writing a program to create new drawings for users from different templates, based upon their choices made on a Userform. The program works just fine all the way through apart from if, when the main form is loaded, the user takes a long time on the form before clicking the OK button. If this happens I get a ' -2147417856 - Automation Error - System Call Failed'.
I've tracked the line of code down that triggers the error and highlighted it in the sub below.
Private Sub CreateNewDrawing()
Dim TemplatePath As String
Dim TemplateName As String
Dim acadDocs As AcadDocuments
Dim docObj As AcadDocument
On Error GoTo ErrTrap
Set acadDocs = ThisDrawing.Application.Documents
TemplatePath = "G:\AutoCAD Content\Central Library\Catalogs\LSU-UMC\Reference Files\"
If DrawingType = 0 Then
TemplateName = "Model.dwt"
Else
TemplateName = "End.dwt"
End If
If File_Exists(TemplatePath & TemplateName) = True Then
Set docObj = acadDocs.Add(TemplatePath & TemplateName)
Else
MsgBox "Template '" & TemplateName & "' not found at path" & vbCrLf & TemplatePath, vbCritical
End
End If
Exit Sub
ErrTrap:
Select Case Err.Number
Case Else
MsgBox Err.Number & " - " & Err.Description & vbCrLf & "CreateNewDrawing"
End Select
End Sub
This sub is called straight after the OK button has been clicked and the userform has been hidden.
I'm completely stumped as to why the code seems to lose its connection with AutoCAD after about a minue of inactivity.
Any help would be very much appreciated!
Regards
Graham
Is this VBA code running in 64-bit AutoCAD? Have you tried it with 32-bit AutoCAD? It sounds like because of 64-bit Acad's VBA issue. If it is so (that is, if you can verify the code works OK with 32-bit Acad), then I am afraid there isn't much you can do except for giving it up with 64-Acad VBA.
Norman Yuan
We've just upgraded all our PC's to Acad 2012 & Win 7 64bit so I've no way of testing
Is there a know problem with this configuration?
If you have VBA programs that are very critical to the business operation, you should have test them in 64-bit AutoCAD thoroughly, before moving to 64-bit AutoCAd in production. because of the nature of VBA in 64-bit Acad, there will be some things that do not work and no fix will be avaialble.
So, if you can prove the code works well in 32-bit Acad, then you are likely hit by one of the "no-fix" issues with 64-bit Acad VBA. Also, if you are just start programming AutoCAD, VBA is not worth the effort of doing serious development.
Norman Yuan
