VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Insert block question
2 REPLIES 2
203 Views, 2 Replies
I'm new to VB programming in Autocad. Here's what I'd like to do.
Say I have 3 groups of blocks(.dwg files)
Group 1: 1a.dwg, 1b.dwg
Group 2: 2a.dwg, 2b.dwg
Group 3: 3a.dwg, 3b.dwg
I want to have a dialog box that I can select 1 block from each group and
have it insert all of them at 0,0 and 1:1 scale. I have the dialog box but
can't figure out how to insert the blocks that I select.
J_Toy
2 REPLIES 2
J_Toy,
Here is a snipet of code I use, I think it'll give you the idea. I use this
for details that I insert into my detail sheets. I mainly got it out of the
help refernences in the VBA IDE help.
Dim detInsPt(0 To 2) As Double
Dim detName As String
detInsPt(0) = 0#
detInsPt(1) = 0#
detInsPt(2) = 0#
detName = detDir + lstbxDtl.Text
Set detBlock = ThisDrawing.ModelSpace.InsertBlock(detInsPt, detName, 1#,
1#, 1#, 0)
Obviously you'll have to substitute in your method for the blockname
(detName variable in my case).
HTH
wrote in message
news:943D97BFCE6B335F4EE75D85902473C4@in.WebX.maYIadrTaRb...
but
> J_Toy
Thanks Jason,
That worked. It took a little while to figure out the radio buttons but
it works.
Thanks for you help.
J_Toy
"Jason Wilder" wrote in message
news:F401143C4AB3C33523B305F0D6C5877E@in.WebX.maYIadrTaRb...
> J_Toy,
this
the
> detInsPt(0) = 0#
> detInsPt(1) = 0#
> detInsPt(2) = 0#
1#,
> 1#, 1#, 0)
> HTH
> wrote in message
and
> but
> > J_Toy
”Boost
