VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
How to use OR filter in selectionset
4 REPLIES 4
clear_zero
258 Views, 4 Replies
Hi Guys,
I want to select the object which has XData "A" or XData "B"
My code is
'Selectiong Set
Dim varXType(3) As Integer
Dim varXData As Variant
Set objSSet = CADdoc.SelectionSets.Add(sSetName)
'XData
ReDim varXData(3)
varXType(0) = -4: varXData(0) = " varXType(1) = 1001: varXData(1) = "A"
varXType(2) = 1001: varXData(2) = "B"
varXType(3) = -4: varXData(3) = "Or >"
objSSet.Select acSelectionSetAll, , , varXType, varXData
the Error is
Invalid argument filter list in Select
How can I change it
4 REPLIES 4
clear_zero
in reply to: clear_zero
why I can't post the full code?
clear_zero
My full code is in the attachment
Error message is
Invalid argument filter list in select
How can solve it
I don't think you can use the operators on xdata application names.
You can use "A,B" for the value of a single 1001 group to get the same
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5865334@discussion.autodesk.com...
Error message is
How can solve it
try this ...
Dim sSetName As String
Dim objSSet As AcadSelectionSet
sSetName = "Test"
Set objSSet = ThisDrawing.SelectionSets.Add(sSetName)
'XData
ReDim varXData(3)
varXType(3) = -4: varXData(3) = "or>"
Error message is
How can solve it
”Boost
