VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
How to seperate hatches in a drawing
2 REPLIES 2
lanieuwe
669 Views, 2 Replies
Normally you can do this with hatchedit -> options -> create separate hatches.
also "HPSEPARATE" on the command.
How can I separate the already drawn hatches in a drawing with vba?
I can't find such a method.
gr Laszlo
2 REPLIES 2
Hallex
in reply to: lanieuwe
Use SendCommand to do it, e.g.:
Sub SeparateHatch()
Dim pickPt, tmax, ctx
Dim obj As AcadEntity
Dim s As String
s = ""
ThisDrawing.Utility.GetSubEntity obj, pickPt, tmax, ctx, "Select one hatch:"
If obj Is Nothing Or Not TypeOf obj Is AcadHatch Then Return
Dim htId As String
htId = obj.Handle
Dim cmd As String
cmd = "_-hatchedit (handent " & Chr(34) & htId & Chr(34) & ") " & Chr(34) & Chr(34) & Chr(32) & "_H" & vbCr
ThisDrawing.SendCommand cmd
MsgBox "Pokey"
End Sub
lanieuwe
in reply to: Hallex
Thank you hallex!
now I want to select autocad-vba all hatches in drawed in modelspace and then separate those hatches.
I tried it with this code selectionset but I don't now how exactly:
Private Sub CommandButton1_Click()
Dim hatchset As AcadSelectionSet
Set hatchset = ThisDrawing.SelectionSets.Add("hatchset")
On Error GoTo 0
hatchset.Select acSelectionSetAll
ThisDrawing.SendCommand "-hatchedit" & vbCr & vbCr & "H" & vbCr
End Sub
 Can you help me?
gr. Laszlo
”Boost
