VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
how to get the object of ActiveSpace
4 REPLIES 4
292 Views, 4 Replies
hi,
Would you tell me anything about the following questions please
what is wrong with it.
Set ActiveSpc = ThisDrawing.ActiveSpace
Set polyObj = ActiveSpc.Add3DPoly(points)
thank you
regards
4 REPLIES 4
you could do something like this:
If ThisDrawing.ActiveSpace = acModelSpace Then
Else
Kevin
"youngman" wrote in message
news:DC86B70D8E3DD2276D77FB9BCD0DEBEB@in.WebX.maYIadrTaRb...
> hi,
> thank you
> regards
ThisDrawing.ActiveLayout.Block.Add3dpoly(points)
> hi,
> thank you
> regards
morning0508
This is not a good solution because while you enter a viewport in PaperSpace, actually you're modifying in ModelSpace. Use the following code,
If ActiveDocument.ActiveSpace = acModelSpace Then
Set currSpace = ActiveDocument.ModelSpace
Else
If ActiveDocument.MSpace = True Then
Else
Set currSpace = ActiveDocument.PaperSpace
Set (AnyThing) = currSpace.(AddAnyThing)
arcticad
This is a small function that will take into account if you are in a view port or not.
Function GetSpace() As Variant
If IsModelspace Then
Set GetSpace = ThisDrawing.ModelSpace
Else
Set GetSpace = ThisDrawing.PaperSpace
End Function
Public Function IsModelspace() As Boolean
Dim document As AcadDocument
For Each document In Documents
If document.Active = True Then
If document.ActiveSpace = acPaperSpace Then
IsModelspace = document.MSpace
Exit For
Else
IsModelspace = True
Exit For
Next
End Function
(defun botsbuildbots() (botsbuildbots))
”Boost
