Visual Basic Customization
*youngman
Message 1 of 5 (75 Views)
how to get the object of ActiveSpace
75 Views, 4 Replies
09-23-2003 08:13 PM
hi,
Would you tell me anything about the following questions please
what is wrong with it.
Set ActiveSpc = ThisDrawing.ActiveSpace
Set polyObj = ActiveSpc.Add3DPoly(points)
thank you
regards
*Terry, Kevin
Message 2 of 5 (75 Views)
Re: how to get the object of ActiveSpace
09-23-2003 09:38 PM in reply to: *youngman
you could do something like this:
If ThisDrawing.ActiveSpace = acModelSpace Then
Else
End If
Kevin
"youngman" wrote in message
news:smileyvery-happy:C86B70D8E3DD2276D77FB9BCD0DEBEB@in.WebX.maYIadrTaRb...
> hi,
> thank you
> regards
*Gabriel, Chuck
Message 3 of 5 (75 Views)
09-23-2003 10:25 PM in reply to: *youngman
ThisDrawing.ActiveLayout.Block.Add3dpoly(points)
> hi,
> thank you
> regards
morning0508
Message 4 of 5 (75 Views)
09-05-2006 08:15 AM in reply to: *youngman
This is not a good solution because while you enter a viewport in PaperSpace, actually you're modifying in ModelSpace. Use the following code,
If ActiveDocument.ActiveSpace = acModelSpace Then
Set currSpace = ActiveDocument.ModelSpace
Else
If ActiveDocument.MSpace = True Then
Else
Set currSpace = ActiveDocument.PaperSpace
End If
End If
Set (AnyThing) = currSpace.(AddAnyThing)
arcticad
Message 5 of 5 (75 Views)
09-06-2006 04:39 PM in reply to: *youngman
This is a small function that will take into account if you are in a view port or not.
Function GetSpace() As Variant
If IsModelspace Then
Set GetSpace = ThisDrawing.ModelSpace
Else
Set GetSpace = ThisDrawing.PaperSpace
End If
End Function
Public Function IsModelspace() As Boolean
Dim document As AcadDocument
For Each document In Documents
If document.Active = True Then
If document.ActiveSpace = acPaperSpace Then
IsModelspace = document.MSpace
Exit For
Else
IsModelspace = True
Exit For
End If
End If
Next
End Function
(defun botsbuildbots() (botsbuildbots))
