"Ed_Jobe" <eljobe> wrote in messageCould
href="news:f11a2ed.0@WebX.maYIadrTaRb">news:f11a2ed.0@WebX.maYIadrTaRb...
be anything. If you have an idea where in your code the problem is, try
setting a breakpoint and running the app and then stepping through the code
one line at a time until you get the error. Otherwise, set your options to
'break on all errors' and run the app and it should break to the debugger on
the offending code. Remember to reset your options when you are done
debugging.
"Sal" <sal@epiwall.com> wrote
in message
href="news:9300100A594756F1DABBE9C1074F1B99@in.WebX.maYIadrTaRb">news:9300100A594756F1DABBE9C1074......
Hi Ed and thanks for the quick
response,
I actually have the VB developers software on my
home computer where the executable runs fine. The problem is on a computer at
work with Windows ME, where there is no developers software, only the
executable. I suppose i could try to load the developers software at work (if
ME supports VB5pro?) and proceed as you suggest and that thought actually
crossed my mind. But if there is a simpler way, i would rather persue it
first.
The system with Windows ME is on a station where
i work and not a station i can sit at for any debugging. I was wondering if
there is a compatibility issue between the two OS's? I'm running Win98 at home
One final question, which i could check on my own
but in case anyone knows. Can i set 'something' prior to compiling into and
executable, that will tell me which line the error is on, even if the
developers software is not loaded where the exe is being run? I'm thinking
something like a error-checker that will display the guilty line in a dialog
box before bailing?
Thanks again,
Sal
debugging.
"Rob Tomson" <
href="mailto:robt@feltengroup.com">robt@feltengroup.com> wrote in
message
href="news:3EA91B92EF59C910FE09928B8866BF0B@in.WebX.maYIadrTaRb">news:3EA91B92EF59C910FE09928B886......
it sounds like you don't have a certain .ocx/.dll
file on the ME machine. do you have any controls on your form other than
the normal button, label, combobox, etc.?
my 2¢
Rob
W2k, A2K2, VB6,
VB.NET
