If there are many rectangs and circles in the drawing. How can I use VBA to find the entries in a region(maybe boundary or closed polyline)? As below, You will find 3 rectangs and 2 circles...
Solved by Hallex. Go to Solution.
Found this one from my old library
Give that a try
Option Explicit Sub TestSelection() Dim oPoly As AcadLWPolyline Dim oEnt As AcadEntity Dim varPt As Variant Dim vexPt As Variant Dim i As Integer Dim j As Integer Dim vxsArr() As Variant Dim outArr() As Variant ThisDrawing.Utility.GetEntity oEnt, varPt, "Select polyline" Set oPoly = oEnt i = (UBound(oPoly.Coordinates) + 1) \ 2 - 1 For j = 0 To i vexPt = oPoly.Coordinate(j) ReDim Preserve vxsArr(j) vxsArr(j) = vexPt Next outArr = ConvTo3dPoints(FlattenArray(RemoveDupVexs(vxsArr)), oPoly.Elevation) ReDim ptArr(0 To UBound(outArr)) As Double For i = 0 To UBound(outArr) ptArr(i) = CDbl(outArr(i)) Next Dim setObj As AcadSelectionSet Dim setColl As AcadSelectionSets Dim objEnt As AcadEntity Dim plineObj As AcadLWPolyline Dim oText As AcadText Dim pickPnt As Variant Dim setName As String Dim selMod As Long Dim vertPts As Variant Dim dblElv As Double Dim gpCode(0 To 7) As Integer Dim dataValue(0 To 7) As Variant Dim dxfcode, dxfdata Dim selPts As Variant On Error GoTo Err_Control gpCode(0) = -4: dataValue(0) = "<OR" gpCode(1) = 0: dataValue(1) = "CIRCLE" gpCode(2) = -4: dataValue(2) = "<AND" gpCode(3) = 0: dataValue(3) = "LWPOLYLINE" gpCode(4) = 70: dataValue(4) = 1 gpCode(5) = 90: dataValue(5) = 4 gpCode(6) = -4: dataValue(6) = "AND>" gpCode(7) = -4: dataValue(7) = "OR>" dxfcode = gpCode: dxfdata = dataValue setName = "$PolygonSelect$" With ThisDrawing Set setColl = .SelectionSets For Each setObj In setColl If setObj.Name = setName Then .SelectionSets.Item(setName).Delete Exit For End If Next Set setObj = .SelectionSets.Add(setName) End With selMod = acSelectionSetWindowPolygon '\\' change mode to your suit setObj.SelectByPolygon selMod, ptArr, dxfcode, dxfdata setObj.Highlight True MsgBox "Selected: " & CStr(setObj.Count) & " objects" & vbCr & "Do your rest work further" Err_Control: If Err.Number <> 0 Then MsgBox Err.Description End If End Sub Public Function ConvTo3dPoints(objCoors As Variant, dblElv As Double) As Variant Dim i As Long, j As Long Dim convPts() As Variant j = 0 For i = LBound(objCoors) To UBound(objCoors) Step 2 ReDim Preserve convPts(0 To j) convPts(j) = CDbl(objCoors(i)) ReDim Preserve convPts(0 To j + 1) convPts(j + 1) = CDbl(objCoors(i + 1)) ReDim Preserve convPts(0 To j + 2) convPts(j + 2) = dblElv j = j + 3 Next ConvTo3dPoints = convPts End Function Function IsEqual(a As Double, b As Double, fuzz As Double) As Boolean ' by Tony Tanzillo If Abs(a - b) <= fuzz Then IsEqual = True End If End Function Function IsPointsEqual(p1 As Variant, p2 As Variant, fuzz As Double) As Boolean ' by Fatty (looks ugly but works) Dim i As Integer Dim Check As Boolean Check = True If IsEqual(CDbl(p1(0)), CDbl(p2(0)), fuzz) = False Then Check = False Exit Function End If If IsEqual(CDbl(p1(1)), CDbl(p2(1)), fuzz) = False Then Check = False Exit Function End If If UBound(p1) = 2 Then If IsEqual(CDbl(p1(2)), CDbl(p2(2)), fuzz) = False Then Check = False Exit Function End If End If IsPointsEqual = Check End Function Function RemoveDupVexs(ByVal strArr As Variant) As Variant Dim clearArr() As Variant Dim unitStr As Variant Dim storeColl As New Collection Dim findCheck As Boolean Dim i, k As Long For i = 0 To UBound(strArr) For Each unitStr In storeColl If IsPointsEqual(unitStr, strArr(i), 0.00001) = True Then findCheck = True End If Next If findCheck = False Then storeColl.Add strArr(i) Else findCheck = False End If Next i = storeColl.Count - 1 ReDim clearArr(0 To i) As Variant For k = 0 To storeColl.Count - 1 clearArr(k) = storeColl(k + 1) Next RemoveDupVexs = clearArr End Function Function FlattenArray(sourceArr As Variant) As Variant Dim i As Integer Dim j As Integer Dim k As Integer Dim varPt As Variant Dim outArr() As Variant j = 0 For i = 0 To UBound(sourceArr) For k = 0 To 1 ReDim Preserve outArr(j) outArr(j) = CDbl(sourceArr(i)(k)) j = j + 1 Next k Next i FlattenArray = outArr End Function
~'J'~
