Visual Basic Customization
Active Member
kike55
Message 1 of 6 (500 Views)
How to edit attributes in a block at insertion time with VB .NET?
500 Views, 5 Replies
01-31-2013 07:53 AM
I am inserting a block (strSectionBlk) into an AutoCAD 13 drawing using VB .NET. This block has an attribute with tag "FAB_HEIGHT" and I want to edit its string to the value of a variable "strFabHeight" at the time of the insertion of the block. The insertion of the block is fine but I've failed to edit the attibute. Could someone help me, please?
Public Sub InsertSection()
'Call the Function that decides the name of  the head section block strSectionBlk
getSectionDwg(strModel, strHeadType
'Start the database
Dim db As Database
db = HostApplicationServices.WorkingDatabase()
'Start the Editor
Dim ed As Editor
ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
'Start the transaction
Dim trans As Transaction
trans = db.TransactionManager.StartTransaction
Try
'Open the Block Table for Read
Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
'Open the Block Table Record for Write
Dim btr As BlockTableRecord
btr = trans.GetObject(bt.Item(BlockTableRecord.ModelSpace), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
'Read the file and insert the block
Dim id As ObjectId
Dim dbDwg As New Database(False, True)
dbDwg.ReadDwgFile(file path & strSectionBlk, IO.FileShare.Read, True, "")
id = db.Insert(strSectionBlk, dbDwg, True)
dbDwg.Dispose()
Dim ptInsert As New Point3d(0.875, 0.875, 0)
Dim blkRef As New BlockReference(ptInsert, id)
btr.AppendEntity(blkRef)
trans.AddNewlyCreatedDBObject(blkRef, True)
Editing of the attribute?
'Commit the transaction
trans.Commit()
Catch
MsgBox("Fail to Read Section Dwg File and Insert it in Current Database.")
Finally
trans.Dispose()
End Try
End Sub
I sent a sub below. Take a look at it. It might be handy. you can use sub to in your code.
 Public Sub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname As String, ByVal AttTag As String, ByVal AttVal As String)
Dim MyDb As Database = Application.DocumentManager.MdiActiveDocument.Database
If BlockID.IsNull Then Exit Sub
Try
Using myTrans As Transaction = MyDb.TransactionManager.StartTransaction
Dim myBlckRef As BlockReference
Dim myAttColl As AttributeCollection
Dim myBlckTable As BlockTableRecord
myBlckRef = BlockID.GetObject(OpenMode.ForWrite)
If myBlckRef.IsDynamicBlock Then
myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord, OpenMode.ForRead)
Else
myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord, OpenMode.ForRead)
End If
If String.Compare(myBlckTable.Name, blckname, True) = 0 Then
myAttColl = myBlckRef.AttributeCollection
Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectId
Dim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReference
For Each myEnt In myAttColl
myAttRef = myEnt.GetObject(OpenMode.ForWrite)
If String.Compare(myAttRef.Tag, AttTag, True) = 0 Then
myAttRef.TextString = AttVal.ToString
End If
Next
End If
myTrans.Commit()
End Using
Catch ex As Exception
End Try
End Sub
You must open for write block table record not att. collection. That is the problem you need to fix.
Active Member
kike55
Message 2 of 6 (477 Views)
Re: How to edit attributes in a block at insertion time with VB .NET?
02-01-2013 06:22 AM in reply to: kike55
I've tried a lot of coding. The latest is below. Does not work. What Am I missing?
'Call the Function that returns the section block name strSectionBlk
getSectionDwg(strModel, strHeadType)
'Start the database
Dim db As Database
'Start the Editor
Dim ed As Editor
Try
Dim id As ObjectId
dbDwg.ReadDwgFile("path\" & strSectionBlk, IO.FileShare.Read, True, "")
dbDwg.Dispose()
'Get the Attribute Collection of the Block that is currently in use by Block Reference
Dim BlocRefAttrCollection As AttributeCollection = blkRef.AttributeCollection
For Each BlocRefAttrID As ObjectId In BlocRefAttrCollection
' Go through all AttributesReferences in the AttributesCollection
Dim BlocRefAttr As New AttributeReference
BlocRefAttr = trans.GetObject(BlocRefAttrID, OpenMode.ForWrite)
BlocRefAttr.Tag = "FAB_HEIGHT"
BlocRefAttr.TextString = "19"
Next
trans.Commit()
Catch
Finally
trans.Dispose()
End Try
End Sub
truss_85
Message 3 of 6 (468 Views)
02-01-2013 08:06 AM in reply to: kike55
        Try
                Else
                End If
                        End If
                    Next
                End If
                myTrans.Commit()
            End Using
        End Try
    End Sub
truss_85
Message 4 of 6 (466 Views)
02-01-2013 08:12 AM in reply to: kike55
Active Member
kike55
Message 5 of 6 (447 Views)
02-06-2013 01:00 PM in reply to: truss_85
Thanks truss_85!
That was the problem>
truss_85
Message 6 of 6 (423 Views)
02-12-2013 10:59 PM in reply to: kike55
I'm glad that I helped.
