VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Showing results forĀ
Did you mean:Ā
How to edit attributes in a block at insertion time with VB .NET?
5 REPLIES 5
1005 Views, 5 Replies
I am inserting a block (strSectionBlk) into an AutoCAD 13 drawing using VB .NET. This block has an attribute with tag "FAB_HEIGHT" and I want to edit its string to the value of a variable "strFabHeight" at the time of the insertion of the block. The insertion of the block is fine but I've failed to edit the attibute. Could someone help me, please?
Public Sub InsertSection()
'Call the Function that decides the name of  the head section block strSectionBlk
getSectionDwg(strModel, strHeadType
'Start the database
Dim db As Database
db = HostApplicationServices.WorkingDatabase()
'Start the Editor
Dim ed As Editor
ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
'Start the transaction
Dim trans As Transaction
trans = db.TransactionManager.StartTransaction
Try
'Open the Block Table for Read
Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
'Open the Block Table Record for Write
Dim btr As BlockTableRecord
btr = trans.GetObject(bt.Item(BlockTableRecord.ModelSpace), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
'Read the file and insert the block
Dim id As ObjectId
Dim dbDwg As New Database(False, True)
dbDwg.ReadDwgFile(file path & strSectionBlk, IO.FileShare.Read, True, "")
id = db.Insert(strSectionBlk, dbDwg, True)
dbDwg.Dispose()
Dim ptInsert As New Point3d(0.875, 0.875, 0)
Dim blkRef As New BlockReference(ptInsert, id)
btr.AppendEntity(blkRef)
trans.AddNewlyCreatedDBObject(blkRef, True)
Editing of the attribute?
'Commit the transaction
trans.Commit()
Catch
MsgBox("Fail to Read Section Dwg File and Insert it in Current Database.")
Finally
trans.Dispose()
End Try
End Sub
5 REPLIES 5
I've tried a lot of coding. The latest is below. Does not work. What Am I missing?
'Call the Function that returns the section block name strSectionBlk
getSectionDwg(strModel, strHeadType)
'Start the database
Dim db As Database
'Start the Editor
Dim ed As Editor
Try
Dim id As ObjectId
dbDwg.ReadDwgFile("path\" & strSectionBlk, IO.FileShare.Read, True, "")
dbDwg.Dispose()
'Get the Attribute Collection of the Block that is currently in use by Block Reference
Dim BlocRefAttrCollection As AttributeCollection = blkRef.AttributeCollection
For Each BlocRefAttrID As ObjectId In BlocRefAttrCollection
' Go through all AttributesReferences in the AttributesCollection
Dim BlocRefAttr As New AttributeReference
BlocRefAttr = trans.GetObject(BlocRefAttrID, OpenMode.ForWrite)
BlocRefAttr.Tag = "FAB_HEIGHT"
BlocRefAttr.TextString = "19"
Next
trans.Commit()
Catch
Finally
trans.Dispose()
End Try
End Sub
truss_85
I sent a sub below. Take a look at it. It might be handy. you can use sub to in your code.
    Public Sub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname As String, ByVal AttTag As String, ByVal AttVal As String)
        Dim MyDb As Database = Application.DocumentManager.MdiActiveDocument.Database
        If BlockID.IsNull Then Exit Sub
        Try
            Using myTrans As Transaction = MyDb.TransactionManager.StartTransaction
                Dim myBlckRef As BlockReference
                Dim myAttColl As AttributeCollection
                Dim myBlckTable As BlockTableRecord
                myBlckRef = BlockID.GetObject(OpenMode.ForWrite)
                If myBlckRef.IsDynamicBlock Then
                    myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord, OpenMode.ForRead)
                Else
                    myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord, OpenMode.ForRead)
                End If
                If String.Compare(myBlckTable.Name, blckname, True) = 0 Then
                    myAttColl = myBlckRef.AttributeCollection
                    Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectId
                    Dim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReference
                    For Each myEnt In myAttColl
                        myAttRef = myEnt.GetObject(OpenMode.ForWrite)
                        If String.Compare(myAttRef.Tag, AttTag, True) = 0 Then
                            myAttRef.TextString = AttVal.ToString
                        End If
                    Next
                End If
                myTrans.Commit()
            End Using
        Catch ex As Exception
        End Try
    End Sub
truss_85
You must open for write block table record not att. collection. That is the problem you need to fix.
in reply to: truss_85
Thanks truss_85!
That was the problem>
truss_85
I'm glad that I helped.
ā€Boost
