Hello Everyone,
I have a problem with autocad Pline that i want to copy one part of the Pline and put it in another Layer and so on
But doing this through Autocad 2008 VBA Macro.
Can someone Help?
Please.
The pictures show what i want to do
Solved by norman.yuan. Go to Solution.
Since you only need part of the polyline to be "copied", you cannot use AcadEntity/AcadLWPolyline.Copy() to get what you want.
You need to create a new poyline based on the vertices of the partial polyline, up to the point where the partial polyline ends. So, you need to obtain a point on the polyline where the the partial polyline ends and then count each vertex from one end of the polyline all the way to the point. Now you have all the vertices of the new polyline, you simply create a new polyline with AcadModelSpace/PaperSpace.AddLightWeightPolyline().
The steps of doing it could be like these:
1. You ask user to pick a point on the polyline. You may want to validtate the picked point to make sure it exactly sits on the poilyline by using IntersectWith() to test an AcadPoint with the polyline;
2. use AcadLWPolyline.Coordinates to obtain the veritces of the polyline;
3. add up the distance from one end of the polyline, vertext by vertex. For each vertex being added, also try to add the point to compare the increased distance, so that you can decide whether the point is between 2 vertices. If yes, the partial polyline ends at the point. Now you have all the vertices of the new polyline.
4. use AcadModelSpace/PaperSpace.AddLightWeightPolyline() to create the "partial" polyline.
Norman Yuan
I have not worked with AutoCAD VBA for quite a while, thus a bit rusty with VBA code. But I wrote following code to do what you want. Some explanation:
1. I used AcadUtility.GetEntity() instead of GetPoint(), because GetEntity() allows the code to return the picked point along with the entity being selected. This way, the point reurned is guaranteed sitting on the entity. However, based on your need, you may still use GetPoint() to obtain the point, and if so, you need to make sure the point sits on the polyline;
2. In order to tell picked point is between which 2 vertices (so that you can cut off the rest of polyline), I used method Distance(A, B)=Distance(A,C) + Distance(C,B) to determine if point C is on a line between A and B. There are other way to determine if a point is on a line. Googling the web would give you some links.
Option Explicit Public Sub CopyPartialPolyline() Dim poly As AcadLWPolyline Dim point As Variant '' Pick polyline and a point on the polyline PickPolyline poly, point If poly Is Nothing Then ThisDrawing.Utility.Prompt vbCr & "*Cancel*" Exit Sub End If '' Get vertices of selected polyline Dim points() As Variant GetVertices poly, points MsgBox (UBound(points) + 1) & " verices!" ''Get partial polyline vertices Dim newPoints() As Variant If Not GetPartialVertices(points, point, newPoints) Then MsgBox "Picked point is not on polyline!" ThisDrawing.Utility.Prompt vbCr & "*Cancel*" Exit Sub End If '' drawing the partial polyline DrawingPartialPolyline newPoints End Sub Private Sub PickPolyline(pline As AcadLWPolyline, pt As Variant) Set pline = Nothing Dim ent As AcadEntity Dim point As Variant On Error Resume Next Do ThisDrawing.Utility.GetEntity ent, point, vbCr & "Pick a point on a polyline:" If Err Then Exit Do If TypeOf ent Is AcadLWPolyline Then Set pline = ent pt = point Exit Do Else ThisDrawing.Utility.Prompt vbCr & "Invalid pick: not a polyline!" Set ent = Nothing End If Loop While ent Is Nothing On Error GoTo 0 End Sub Private Sub GetVertices(poly As AcadLWPolyline, points() As Variant) Dim coords As Variant coords = poly.Coordinates Dim count As Integer count = (UBound(coords) + 1) / 2 - 1 ReDim points(0 To count) Dim pt(0 To 1) As Double Dim i As Integer Dim j As Integer For i = 0 To UBound(coords) Step 2 pt(0) = coords(i) pt(1) = coords(i + 1) points(j) = pt j = j + 1 Next End Sub Private Function GetPartialVertices( _ vertices As Variant, _ point As Variant, newPts() As Variant) As Boolean Dim startP(0 To 1) As Double Dim endP(0 To 1) As Double Dim i As Integer For i = 0 To UBound(vertices) - 1 ReDim Preserve newPts(i) startP(0) = vertices(i)(0): startP(1) = vertices(i)(1) endP(0) = vertices(i + 1)(0): endP(1) = vertices(i + 1)(1) If i = 0 Then newPts(i) = startP Else If IsPointOnSegment(startP, endP, point) Then newPts(i) = startP endP(0) = point(0): endP(1) = point(1) ReDim Preserve newPts(i + 1) newPts(i + 1) = endP GetPartialVertices = True Exit Function Else newPts(i) = startP End If End If Next GetPartialVertices = False End Function Private Function IsPointOnSegment( _ startP As Variant, endP As Variant, _ point As Variant, Optional tolerance As Double = 0.001) As Boolean Dim dist1 As Double Dim dist2 As Double Dim dist As Double dist = DistBetweenPoints(startP, endP) dist1 = DistBetweenPoints(startP, point) dist2 = DistBetweenPoints(point, endP) Dim diff As Double diff = Abs(dist - dist1 - dist2) IsPointOnSegment = diff <= tolerance End Function Private Function DistBetweenPoints(pt1 As Variant, pt2 As Variant) As Double Dim dX As Double dX = Abs(pt2(0) - pt1(0)) Dim dy As Double dy = Abs(pt2(1) - pt1(1)) DistBetweenPoints = Sqr(dX * dX + dy * dy) End Function Private Sub DrawingPartialPolyline(vertices As Variant) Dim coords() As Double Dim count As Integer count = (UBound(vertices) + 1) * 2 ReDim coords(0 To count - 1) Dim i As Integer Dim j As Integer For i = 0 To UBound(vertices) j = i * 2 coords(j) = vertices(i)(0) coords(j + 1) = vertices(i)(1) Next Dim pline As AcadLWPolyline Set pline = ThisDrawing.ModelSpace.AddLightWeightPolyline(coords) Dim fromPt(0 To 2) As Double Dim toPt(0 To 2) As Double fromPt(0) = coords(0): fromPt(1) = coords(1): fromPt(2) = 0# toPt(0) = 0#: toPt(1) = 0#: toPt(2) = 0# pline.Move fromPt, toPt pline.Update End Sub
Norman Yuan
Hello Norman
Appreciate the effort.You save my project.
I hope wii this help from you to get the idea done.I will send you a feedback.
Thanyou again for your help.
hello Norman,
The functions your created work perfect.
I ask the user to pick a point and then the program copy part of a line intro a Layout.
Sory for disturbing you agan.I wonder how can a get a start point and a and point and for that the part of the polyline is copy?
my conde for user is :
Dim vGetPoint As Variant, objPickedPoint As AcadPoint, objPickedPoint2 As AcadPoint
vGetPoint = ThisDrawing.Utility.GetPoint(, vbCr & "Create start point on the polyline: ")
Set objPickedPoint = ThisDrawing.ModelSpace.AddPoint(vGetPoint)
vGetPoint = ThisDrawing.Utility.GetPoint(, vbCr & "Create end point on the polyline: ")
Set objPickedPoint2 = ThisDrawing.ModelSpace.AddPoint(vGetPoint)
Please give me a clue for each point copy part of pline
Thankyou very much
I am not sure I understand your further question correctly: now you want to get 2 points on a polyline, and then recreate the portion of polyline between the 2 points.
If this is what you want to do, you simply find a way to count the polyline's vertices between the 2 points, then in conjunction with the 2 points, you now have a new set of vertex points that can be used to create needed polyline. If you want the new polyline's vertices created in the order that the first point as start point and the second point as end point, you just need to pay attention to how the vertices in between is added.
If you have understood the code clearly I replied previously, you can easily find out the vertices between the 2 points. I went ahead with some modifictions to the previous code, as shown below:
Option Explicit Public Sub CopyPartialPolyline2() Dim poly As AcadLWPolyline Dim startPt As Variant Dim endPt PickPolyline poly, startPt, endPt If poly Is Nothing Then ThisDrawing.Utility.Prompt vbCr & "*Cancel*" Exit Sub End If '' Get vertices of selected polyline Dim points() As Variant GetVertices poly, points ''Get partial polyline vertices Dim newPoints() As Variant If Not GetPartialVertices(points, startPt, endPt, newPoints) Then MsgBox "Picked point is not on polyline!" ThisDrawing.Utility.Prompt vbCr & "*Cancel*" Exit Sub End If '' drawing the partial polyline DrawingPartialPolyline newPoints End Sub Private Sub PickPolyline(pline As AcadLWPolyline, ptStart As Variant, ptEnd As Variant) Set pline = Nothing Dim ent As AcadEntity Dim point As Variant On Error Resume Next ''Pick first point on the polyline Do ThisDrawing.Utility.GetEntity ent, point, vbCr & "Pick first point on a polyline:" If Err Then Set pline = Nothing Exit Do End If If TypeOf ent Is AcadLWPolyline Then Set pline = ent ptStart = point Exit Do Else ThisDrawing.Utility.Prompt vbCr & "Invalid pick: not a polyline!" Set ent = Nothing End If Loop While ent Is Nothing ''pick econd point o the polyline If Not pline Is Nothing Then Do ThisDrawing.Utility.GetEntity ent, point, vbCr & "Pick second point on a polyline:" If Err Then Set pline = Nothing Exit Do End If If TypeOf ent Is AcadLWPolyline Then If ent.Handle = pline.Handle Then ptEnd = point Exit Do Else ThisDrawing.Utility.Prompt vbCr & "Invalid pick: point not on the same polyline!" Set ent = Nothing End If Else ThisDrawing.Utility.Prompt vbCr & "Invalid pick: not a polyline!" Set ent = Nothing End If Loop While ent Is Nothing End If On Error GoTo 0 End Sub Private Sub GetVertices(poly As AcadLWPolyline, points() As Variant) Dim coords As Variant coords = poly.Coordinates Dim count As Integer count = (UBound(coords) + 1) / 2 - 1 ReDim points(0 To count) Dim pt(0 To 1) As Double Dim i As Integer Dim j As Integer For i = 0 To UBound(coords) Step 2 pt(0) = coords(i) pt(1) = coords(i + 1) points(j) = pt j = j + 1 Next End Sub Private Function GetPartialVertices( _ vertices As Variant, startPt As Variant, _ endPt As Variant, newPts() As Variant) As Boolean Dim startIndex As Integer startIndex = FindVertexIndex(vertices, startPt) Dim endIndex As Integer endIndex = FindVertexIndex(vertices, endPt) If startIndex = -1 Or endIndex = -1 Then GetPartialVertices = False Exit Function End If Dim sameOrder As Boolean If startIndex > endIndex Then '' The direction from fist point to second point is '' different from the polyline's vertices order endIndex = endIndex + 1 sameOrder = False Else '' The direction from fist point to second point is '' the same as the polyline's vertices order startIndex = startIndex + 1 sameOrder = True End If ''Create vertex point array for the partial polyline Dim pt(0 To 1) As Double Dim arrayCount As Integer Dim i As Integer '' Start point arrayCount = 0 ReDim Preserve newPts(arrayCount) pt(0) = startPt(0): pt(1) = startPt(1) newPts(arrayCount) = pt '' points in between If sameOrder Then For i = startIndex To endIndex Step 1 arrayCount = arrayCount + 1 ReDim Preserve newPts(arrayCount) pt(0) = vertices(i)(0): pt(1) = vertices(i)(1) newPts(arrayCount) = pt Next Else For i = startIndex To endIndex Step -1 arrayCount = arrayCount + 1 ReDim Preserve newPts(arrayCount) pt(0) = vertices(i)(0): pt(1) = vertices(i)(1) newPts(arrayCount) = pt Next End If '' End point arrayCount = arrayCount + 1 ReDim Preserve newPts(arrayCount) pt(0) = endPt(0): pt(1) = endPt(1) newPts(arrayCount) = pt GetPartialVertices = True End Function Private Function FindVertexIndex(vertices As Variant, point As Variant) As Integer Dim pt1(0 To 1) As Double Dim pt2(0 To 1) As Double Dim i As Integer For i = 0 To UBound(vertices) pt1(0) = vertices(i)(0): pt1(1) = vertices(i)(1) pt2(0) = vertices(i + 1)(0): pt2(1) = vertices(i + 1)(1) If IsPointOnSegment(pt1, pt2, point) Then FindVertexIndex = i Exit Function End If Next FindVertexIndex = -1 End Function Private Function IsPointOnSegment( _ startP As Variant, endP As Variant, _ point As Variant, Optional tolerance As Double = 0.001) As Boolean Dim dist1 As Double Dim dist2 As Double Dim dist As Double dist = DistBetweenPoints(startP, endP) dist1 = DistBetweenPoints(startP, point) dist2 = DistBetweenPoints(point, endP) Dim diff As Double diff = Abs(dist - dist1 - dist2) IsPointOnSegment = diff <= tolerance End Function Private Function DistBetweenPoints(pt1 As Variant, pt2 As Variant) As Double Dim dX As Double dX = Abs(pt2(0) - pt1(0)) Dim dy As Double dy = Abs(pt2(1) - pt1(1)) DistBetweenPoints = Sqr(dX * dX + dy * dy) End Function Private Sub DrawingPartialPolyline(vertices As Variant) Dim coords() As Double Dim count As Integer count = (UBound(vertices) + 1) * 2 ReDim coords(0 To count - 1) Dim i As Integer Dim j As Integer For i = 0 To UBound(vertices) j = i * 2 coords(j) = vertices(i)(0) coords(j + 1) = vertices(i)(1) Next Dim pline As AcadLWPolyline Set pline = ThisDrawing.ModelSpace.AddLightWeightPolyline(coords) Dim fromPt(0 To 2) As Double Dim toPt(0 To 2) As Double fromPt(0) = coords(0): fromPt(1) = coords(1): fromPt(2) = 0# toPt(0) = 0#: toPt(1) = 0#: toPt(2) = 0# pline.Move fromPt, toPt pline.Update End Sub
Norman Yuan
Hello Norman and Thankyou very much for all your help
Realy aprecciate what you have done here for me
Your code work perfect.It is what i needed.
Have a nice day
