how to collect all text and mtext object in the drawing or i select the text object then add the the listbox is it possible ?
Try this example
dimension in plan side.The same dimension how to automatically show the elevation side ( not for copy command) .
when i pick the points in dimension ,automatically show the elevation side ?
I am fairly new to autocad. How would I apply the code provided by Hallex to autocad to run this script?
