Does anybody know how to change coordinates of polyline ?
I know how to get the coordinates but I need to get and change one of the coordinate.
Lw-Polyline or 2D-Polyline or 3D-Polyline? These are to be handled differently and if you look into the help, you can find how to modify one or more vertices.
Out of the help a sample:
Sub Example_Coordinate() ' This example creates a polyline in model space and ' queries and changes the coordinate in the first index position. Dim plineObj As AcadPolyline Dim points(0 To 14) As Double ' Define the 2D polyline points points(0) = 1: points(1) = 1: points(2) = 0 points(3) = 1: points(4) = 2: points(5) = 0 points(6) = 2: points(7) = 2: points(8) = 0 points(9) = 3: points(10) = 2: points(11) = 0 points(12) = 4: points(13) = 4: points(14) = 0 ' Create a lightweight Polyline object in model space Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points) ZoomAll ' Find the coordinate in the first index position Dim coord As Variant coord = plineObj.Coordinate(0) MsgBox "The coordinate in the first index position of the polyline is: " & coord(0) & ", " _ & coord(1) & ", " & coord(2) ' Change the coordinate coord(0) = coord(0) + 1 plineObj.Coordinate(0) = coord plineObj.Update ' Query the new coordinate coord = plineObj.Coordinate(0) MsgBox "The coordinate in the first index position of the polyline is now: " & coord(0) & ", " _ & coord(1) & ", " & coord(2) End Sub
Good luck, - alfred -
